Slow and getting slower
Old Aug 4, 2011 | 10:21 PM
  #171
Amedee's Avatar
I love my yank pt 3200 although im runnin a 60e
Did i miss something you runnin 60e r 80e?
Old Aug 4, 2011 | 10:26 PM
  #172
Atomic's Avatar
I have a gauge for that
80e, but the converter is made to fit on the 60e flexplate bolt pattern so you dont need a spacer..
Old Aug 4, 2011 | 10:28 PM
  #173
Bill Reid's Avatar
Interesting... wonder whats up with the .cc of their website...
Old Aug 4, 2011 | 10:33 PM
  #174
Amedee's Avatar
Intresting so this is a custom built verter?
Old Aug 4, 2011 | 11:37 PM
  #175
Atomic's Avatar
I believe he has been doing the 6 bolt thing for a long time, you just tell him what trans its for and what flexplate you want to use. I specifically requested the 6 bolt ls1 pattern.
Old Aug 6, 2011 | 09:50 AM
  #176
Atomic's Avatar
So I realized last night I made a mistake when checking pushrod length; I was checking cylinder number 1 when I should have been checking cyl 6. Base circle of number 1 is with the cam gear dot at 12 and crank dot at 12, not cam at 6 and crank at 12 (cyl 6). Rechecked and got zero lash measurements of 7.25 on the intake and 7.225 on the exhaust, so the 7.300 3/8" pushrods I got will still work fine, just with slightly less preload than originally (0.075).
Old Aug 6, 2011 | 01:15 PM
  #177
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
I've kinda been following your builds, but can you explain the background behind all the scars on the flexplate?
Old Aug 6, 2011 | 01:21 PM
  #178
Atomic's Avatar
Yea the torque converter bolts came out and got trapped between the engine and flexplate
Old Aug 6, 2011 | 01:36 PM
  #179
Beatdown Z's Avatar
Laid Back
Don't know if you've already done it or not, but you may want to remove the coating around the bolt holes on that flexplate. Search TCI flexplates on LS1tech and you'll see what i'm talking about.
Old Aug 6, 2011 | 01:38 PM
  #180
Bumpers's Avatar
That should still be fine.. From what I read the ls7s like alittle more preload closer to .100 but as long as it doesn't make a lot of racket you should be just fine
