Saab 97X 5.3 to LQ9 swap
Old 09-21-2017, 07:08 AM
  #21
thebrain's Avatar
hopfully the wd40 will loosen the rust.
observing the Pass side of engine the airbox covers alot so doe's the AC stuff. I hope this isn't a knuckel buster.
how to turn off rear windshield wiper?
Old 09-21-2017, 09:10 PM
  #22
FFDP's Avatar
Sounds like the rear air bags leak if they drop 8in in the back when you shut the truck off.
The airbags are factory, it's a SAAB thing.
thebrain (09-21-2017)
Old 09-21-2017, 10:18 PM
  #23
thebrain's Avatar
here she is just after turn off.
I removed intake manie/ all but 2 dir. side header bolts , none on Pass side.
removed wiper resuoir it had a bunch of hindin attachments
remove center rad. core surport.
Old 09-23-2017, 07:24 AM
  #24
thebrain's Avatar
my friend had the fan clutgch removale tool, so I have fan unbolted from shaft.
removed trans. cooling lines on pass. side of rad.
crawled under saw two more none compression lines at bottom of rad. is this transfer case cooling?
Old 02-24-2018, 07:55 PM
  #25
thebrain's Avatar
been working on the Saab for last couple weekends restoring colasped lifter replaced all AFMs on driver bank.
last weekend buttoned up and torqued head,now got assembled heads, exhaust,mannie and waterpump.
alternater bracket/rad. is next replug stuff in. mite get her cranked tomorrow.
do all 97x have bubbleing paint on the hood?
Old 02-26-2018, 08:28 AM
  #26
408gto's Avatar
All gto ls2's are 24x u can buy a 58x to 24xconversion box from lingerfelt for couple hundred they are less than $500 and then you can run a gen 3 if you want
Old 03-04-2018, 10:22 PM
  #27
thebrain's Avatar
update completed AFM lifter replacement basiclley shes stock and purring like a kitten.
been cruising around backyard and once around block.
First observation the trans shifts very hard from 1st to 2nd also 2nd to 3rd
I actually grabbed the driveshaft and was able to twist it maybe because the U-jionts are worn out? Driveshaft should not be able to move/twist correct even when wheels have no weight on them. Worn driveshaft will cause jerking when shifting?
Completed the air bag to conventional spring and new shocks the 97x is up there
Havn’t mearsured yet but estimate receivers ball around 22” way more than the van.
97x feels stronge when accelerating if I drop trans fuild pan will a shift kit be identified?
thanks
Archaic2021
04-19-2017 10:10 AM
01FormulaTA
04-18-2017 04:07 AM
brandon6.0
02-03-2017 08:31 AM
brandon6.0
02-01-2017 06:38 PM
Barely Boosted
05-07-2004 07:18 AM
Quick Reply: Saab 97X 5.3 to LQ9 swap
