Ride Tech coil over install
Old Mar 22, 2015 | 08:50 PM
Sofa King Slow Racing's Avatar
Registered User
Default Ride Tech coil over install
First let me say there's a ton of great info on this site! I have learned much.
After doing some reading about others experiences with coil over instals, I pulled the trigger.
My truck is a 2003 Silverado std cab, short bed. I went with the 6.1 stroke single adjustables with 800# springs. They recommended to go with a plate and bracket for the upper mount, as to get away from the stud mount. I got a pair of Strong Arm lower control arms also.
This truck has been lowered its whole life using a Belltech 4/3 kit and had Edlebrock shocks. So far the ride is about the same stiffness wise, but handles better! Zero body lean and no bounce at all. The ride hight stayed the same too. Bonus!
Also was time for new brakes. I went with EBC GT 13 inch dimpled and slotted rotors, Green stuff pads, and new calipers.
Paul
Old Mar 22, 2015 | 09:31 PM
GWEE's Avatar
That's awesome do you have any better pics of the suspension and brakes?
Old Mar 23, 2015 | 08:40 AM
Registered User
I have to do a single pic each time here.....
Old Mar 23, 2015 | 08:42 AM
Registered User
Default Ride Tech coil overs
Brake pic. Love the black! Wish they would stay this way.
Old Mar 23, 2015 | 08:43 AM
Registered User
And another one...
Old Mar 23, 2015 | 05:52 PM
BigKID's Avatar
I hope you meant to type "4.1" stroke. Ridetech doesn't make a 6.1 and I feel the 6.3 would be too long. Interesting they recommended a 4.1 eye-eye with adapter and strong arm. When I spoke with them, the recommendation was a 3.6 stud top with strong arm lower for ~4" drop.
Setup looks really good though and glad to hear the RT's are performing to your expectations.
Old Mar 25, 2015 | 03:58 PM
doc350's Avatar
Do you have any pics of the way you did the top mount? Also, are you still using the stock upper control arms? I am really interested in getting a set of these.
Old Mar 30, 2015 | 08:16 AM
Registered User
Default Ride tech coil over install
I didn't get a pic of the upper mounts. Basically it's a flat round plate that has a pair of tabs welded on. It then bolts through the factory mount. The coil overs use a cross bolt through the tabs. This is way less stressful then the stud mount and has more movement.
And Ya they are the 4.1 inch stroke. The lower CAs have a dropped mount, I think it's 2 inch lower than stock, and am running 2 inch dropped spindles. This package gives me the same 4 inch drop as before but rides and handles way better!
I measured the shock length at ride hight and gave them the numbers. I think it was 13.5 inch from mount to mount.
USMCvet0311
Sep 30, 2015 10:34 AM
TimDave217
Aug 24, 2015 04:38 PM
Denali08
Aug 9, 2015 04:34 PM
lsxmalibu
Jul 29, 2015 07:08 AM
