RCSB build
Old Feb 12, 2012 | 12:51 AM
  #241
smokeshow's Avatar
Mod with training wheels
Originally Posted by schino
you do the 'syty shuffle' ? if i hold the brakes hard and rev up to about 1500 and let it fall back down to idle a few times i can build 13lbs without pushing. i know this is the newer body truck though. how many degrees you running? awesome that the nitrous is cutting the knock hahaha. oh and 118 trap is good! should net you an 11.5 at least with no more hp
Yeah I did try the shuffle, and it didn't really help much. It got me wondering if I have a check valve on the brake booster like the last truck did. This brake booster assembly is a bit different so it may not have the valve.
Originally Posted by A Low Dime
So that is 10psi and 50 shot?
Yes. I jetted it rich because I didn't have a perfect pair of jets to match the mixture right. The bottle heater was also taking a ****, so the hits were really soft. It went a whole point richer in AFR, so I'm sure that soaked up quite a bit of the additional power the nitrous provided...
Originally Posted by Atomic
Why is that surprising that spraying meth got rid of knock?
I didn't say it was surprising.
Originally Posted by AKlowriderZ71
What does the rest of the timeslip look like? That's 6 mph faster than my 11.8x run. I'll be Capt Obvious and say it's got alot more left in it.
Can't wait to see how it does once you get her all dialed in!
Can't wait either! Will post up the slip and videos tomorrow
Originally Posted by Beatdown Z
Does the engine still hate timing? You were only able to run about 8 degrees in your last truck, right?
This one takes more timing, as I have the better plugs in it. I can run 15 degrees, but after IATs heat up by about 3rd gear during a pass, I start seeing KR. I made the IAT spark table pull timing more aggressively to compensate. But spraying nitrous/meth mixture was able to kill all the KR too Hopefully with the meth kit in, I will be able to run 18-20 degrees on 10psi.
Old Feb 12, 2012 | 06:08 AM
  #242
joeyc125's Avatar
11 Second Truck Club
I bet you don't have a check valve, my 05 crew cab didn't have one, push through at 1 psi. Put a check valve in the line, build 7psi easy
Old Feb 12, 2012 | 06:29 AM
  #243
joeyc125's Avatar
Btw, that's a pretty nice mph on that run. I'd say you did pretty good, especially since its your first run after such a complete tear down and rebuild of a different truck!
Old Feb 12, 2012 | 10:38 AM
  #244
smokeshow's Avatar
Check valve it is
Old Feb 12, 2012 | 10:59 AM
  #245
chevyboy.520's Avatar
I thought u had a check valve for that already? Or did you no have one on the brake booster line yet?
Old Feb 12, 2012 | 11:05 AM
  #246
smokeshow's Avatar
No, the other truck had a check valve built in. I assumed this truck did too.
Old Feb 12, 2012 | 01:23 PM
  #247
smokeshow's Avatar
Fixed it! Little syty shuffle from a dig and its a ******* monster now. A friend who was riding with me said it pulls harder than rides at the county fair
Old Feb 13, 2012 | 09:40 PM
  #248
smokeshow's Avatar
11 8@118 - YouTube
Old Feb 13, 2012 | 09:50 PM
  #249
blue0453's Avatar
where is the best place to get the check valve smoke.. truck is bad *** bro, I have been following your whole thread.
Old Feb 13, 2012 | 10:08 PM
  #250
AudioPh1x's Avatar
damn talk about a sleeper haha. nice build man
