Project Kermit
Old Aug 12, 2009 | 12:15 PM
  #471
charcold-bowtie's Avatar
tempting.. And on my last 8 tranny swap Ive gotten to slide the tranny under the truck then put it on the jack. Its so fun that way!
Im ready to see the the intake results, even NA. hurry up.
Old Aug 12, 2009 | 12:24 PM
  #472
Spoolin's Avatar
GFYS and STFU
LOL...I'm hurrying I'm hurrying!!!!
I am going to buy a tranny jack...that was ridiculous!!
Old Aug 12, 2009 | 03:43 PM
  #473
thunderwagen's Avatar
Hopefully you don't have to pull it again
Old Aug 12, 2009 | 08:59 PM
  #474
Spoolin's Avatar
GFYS and STFU
I don't think I'll be pulling the tranny out but I might have to pull the engine out to swap out the oil pan. If the oil cooler lines leak then I'm gonna try and re-tap the bolt holes but if that doesn't work or get's messy than I'll just swap the pan out. But I did get a few things done today...
Old Aug 12, 2009 | 09:09 PM
  #475
Spoolin's Avatar
GFYS and STFU
So the Fed-ex guy showed up with some presents!!
However they weren't exactly for the truck! I ordered a peg board like a month ago and it finally got here so I spend the better part of the morning mounting it to the cinder block wall.
This is what it looked like when I finally got it mounted...
I spend a good two hours organizing the tool organizers on the peg board because I'm OCD and eventually got them set-up pretty good, got the bench moved back and now I have a clear work space!
So moving on, I was kinda limited in what I could do today because I'm waiting on some parts/gaskets to show up at a dealership which will hopefully be tomorrow (fingers crossed). However when I was cleaning my bench up and sorting through some random bolts I had from my last truck I found this!
So I went ahead and swapped it out but those bolt holes are not in good shape! (well see how well it holds and at the first sign of a drop of oil I'm gonna retap that hole. I also bolted on my freebie-alternator!! (Thank you big D!!! )
Old Aug 12, 2009 | 10:48 PM
  #476
BlownChevy's Avatar
blownerator
25 Year Member
I have a tap and die set you can borrow if needed.
Old Aug 12, 2009 | 11:15 PM
  #477
usabodyguard's Avatar
Blown 427 LSX
Old Aug 12, 2009 | 11:19 PM
  #478
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by usabodyguard
blow me *****
Old Aug 12, 2009 | 11:52 PM
  #479
SincalT/A's Avatar
And people wonder why he's constantly pissed.
Old Aug 13, 2009 | 12:46 AM
  #480
Spoolin's Avatar
GFYS and STFU
Cool thanks B!! I will definitely be hitting you up if the need arises! Thanks for the offer!! Also, I was kinda hoping you'd stop by and say hi on your way home yesterday but you were in a hurry I guess!
I have to swing by your neck of the woods and return some fuel rail fittings at Hawaii Racing tomorrow. Can't believe how expensive a damn fitting is!
