Project Kermit
Old Aug 13, 2009 | 01:11 AM
  #481
1FastBrick's Avatar
Custm2500's Rude Friend
All you need is a heli coil repair kit.... or if your to lazy swing back down and swap it out with one of my oil pans...
Old Aug 13, 2009 | 01:39 AM
  #482
Spoolin's Avatar
GFYS and STFU
What's a heli coil repair kit and what does it do? I think if I tap and die the hole over again that would be me being lazy! Pulling the engine out again would be the right thing to do but I'd rather not at this point, I'll probably be going out to sea within a month so I'd like to get it running as soon as I can.
Old Aug 13, 2009 | 01:56 AM
  #483
usabodyguard's Avatar
Blown 427 LSX
yea thats what i was telling you about the other day... I had a heli coil repair done to a seadoo when I sheared off the headers... remember I couldnt remember the name of it??
Heli coil ftw
Old Aug 13, 2009 | 09:42 AM
  #484
1FastBrick's Avatar
Its a metal thread that get inserted in place of the damaged threads. You drill out the hole to a larger size and tap it for a larger thread. Then you put the steel insert in there and puts it back to the original thread size. Its Just as strong but better since the steel Thread is less likely to strip.
Heli coil Is actually a brand Name.
Your basically looking for a Thread repair kit. Read this info. Should be able to get it at any auto parts store. If I know the size I can get one for you. Don't make me dig through my Pile of stuff.
http://www.helicoil.in/helicoil.htm
Old Aug 13, 2009 | 09:44 AM
  #485
00ChevyScott's Avatar
Wearin' da big hat
I just woke up and read that and thought you said a helicopter repair kit
Ya Heli Coil kits work pretty good most of the time
Old Aug 13, 2009 | 11:00 AM
  #486
built408's Avatar
I would put a time-sert in it. Its alot stronger the a heli-coil.
Old Aug 13, 2009 | 11:44 AM
  #487
Spoolin's Avatar
GFYS and STFU
... Don't make me dig through my Pile of stuff.
I don't even know what to say to that!!
Ohhhh boy...
Ok, so basically, which one is the easiest to do while the engine/oil-pan is still in (space sensitive) and will last? I've tap'ed a few holes (Mangled I'm not directing this at you but PM if this turns you on...) in my life so I'm comfortable doing that if necessary.
never done heli-coil or a time-sert but definitely up for learning and doing something new!
Old Aug 13, 2009 | 11:58 AM
  #488
00Silv4.8's Avatar
Jesus, ur still breaking **** and the truck isnt even running?!?!
nice work bench tho haha
Old Aug 13, 2009 | 03:24 PM
  #489
BlownChevy's Avatar
blownerator
25 Year Member
I am sure if you chase the threads with a die they will be fine.
Old Aug 13, 2009 | 03:42 PM
  #490
thunderwagen's Avatar
And for clarification that's a die not a guy! Lmfao
