Project Kermit
#971
The Motor for the GSX is going together. Hope to atleast get in the car withen the next 2 weeks. only need to get an oil pump, timing belt water pump. and supposedly my New cam Blanks are waiting for me to go down and grind them but you know how much time I have for that...
#972
GFYS and STFU
The only thing that will be different between the status of your projects now and when I come back is you'll have more pieces for them but none of them assembled.
Speaking of things laying around, should I disconnect the battery while I'm gone? It'll sit for about 2-3 months before anyone fires it up again. I already drained the fuel tank so that should be good, or damn, should I fill it up so no condesation collects in the tank...
#973
Even though you won't be gone to long it still good practice. run some cleaer through the fuel system when you fill it back up.
not sure if any one will be around were your storing it but you can get a battery tender that will help keep a trickle charge on the battery so it doesnt just go dead while your gone.
#974
I would drain the tank, leave the cap slightly loose so it can breathe. Set the truck frame on jack stands, let the suspension hang (no flat spots on the tires).
Sitting for only 3 or 4 months isn't a real biggy. I have let them sit for over a year in the field and it didn't hurt them.
#978
GFYS and STFU
Your wife would Kill me Bill! I have more sense than that silly rabbit!!
Speaking of common sense(and having none), I gave Richard a call today for him to put in an order for an LSX Tall deck iron block...
#979
