Project "Featherweight" LS swap S10
Old Dec 21, 2015 | 10:39 PM
Black'Rado's Avatar
Default Project "Featherweight" LS swap S10
Just started my newest project. A small tire "streetable" ls powered s10. Plan is swap my old 5.3 from my 01 silverado into it backed with a powerglide. direct port nitrous. 10 pt cage and alluminum dash. stock style suspention with a 28x10.5 slick under it.
The motor already has a 220/220 .581/.581 112lsa cam, comp valve springs and pushrods. 42lb injectors and rest is stock. i have a set of 799 heads i may mill and have ported to swap on and also a tbss 90mm intake. or may just leave it alone and go to a holley mid rise down the road.
the build will be slow as i work 28 days and only home for 14. i am stacking up parts slowly and then should come together quickly. i have already pulled the old 350/350 combo out and stripped the firewall and dash out. i plan on making it light as possible so i will be cutting the engine crossmember and putting tube in place, as well as maybe the front frame horns. tubular arms, fiberglass fenders and hood and maybe building own core support.
here is a quick list of what some parts i plan to use
Engine:
ebay engine plates
ebay foward turbo style headers and build my own fender exits
carshop solid 2.8 style mounts
modify harness for stand alone
Aeromotive A1000 pump and regulator
ebay fuel rails
8 gallon fuel cell
if i do headswap ill need .040 cometic gaskets, ebay head studs, ls7lifters with ls2 trays and new pushrods
if i swap to tbss intake ill need 90mm cable throttle body
Trans:
looking for powerglide to have buiit by local guy or crate one unsure of from who though
nitrous converter 4000ish stall
trans brake an rmvb
b&m or tci shifter
Safety:
10pt cage from brokedick racing
kirkey alum seats
5 point harnesses
alum dash with autometer gages or heads up composite dash
lightweight column
Front suspention:
speedway 8.5'' uppers
trz lowers
moroso trick springs
qa1 shocks
trz rack an pinion
race brakes unsure of what brand yet
Rear suspention:
8.8 swap
calvert split mono
caltracs
qa1 shocks
Nitrous system:
Induction solutions direct port
1 gallon stand alone cell
holley low pressure pump and regulator
progressive controller unknown on what one yet
Body:
glass front fenders
glass 4'' lift off cowl
glass bumper an roll pan
lexan windows
stripped doors with alum door panels
unsure on what i want to do with the bed yet. (gut floor or leave alone)?
silver/grey color paint job
new lights all around
Wheels/tires:
Dark Stars
15x10 rear with hoosier 28x10.5 slick
15x3.75 front with hoosier 27x4.5
im sure things will change over time but thats the base plan......now on to some pics!
pulling the 350 out
out and ready to take it to my shop
goin to its resting place for the build
this **** gota go!
thats better
firewall cleaned off
hung the front cap back on for now
Aeromotive A1000 pump i got for a killer deal
thats all for now, after new years the cage will ordered and ill be working on that and a dash setup.
any opinions or suggestions are welcome. im new to the s10 world. always had fast trucks but never a dedicated racer. my 01 ext cab silverado went 12.7s on a 275 radial an i daily drove it. my current duramax i built is a low 12 high 11 truck i daily drive. heres a pic of it....
Old Dec 21, 2015 | 10:57 PM
Petraszewsky's Avatar
Looks to be a good start. From the title I instantly thought featherweight frame from auto weld.
Old Dec 21, 2015 | 11:12 PM
Black'Rado's Avatar
I wish! one day i do plan to either back half it or build my own 2x3 frame rails
Old Dec 22, 2015 | 07:58 AM
BigKID's Avatar
Cool project! I look forward to seeing your progress on it.
I know you already have it and want to keep things economical, but I would rethink your cam choice. With the turbo forward headers (basically unequal length shorties) and nitrous you are going to want a cam that will rev higher with a bit of exhaust bias.
Old Dec 22, 2015 | 10:51 AM
Black'Rado's Avatar
yes the cam will be changed after its up an running. and also ill be looking for a 6.0 block to build a 370 or 408 that will go in after i pop the 5.3. i may just go ahead and swap the cam regardless to something that would work in the new motor, 244/248 .612/.615 112+2 is one i have in mind. pretty healthy for the 5.3 but should be nice for the 6.0 and ported/milled 799s.
Old Dec 22, 2015 | 11:00 AM
Z71crawford's Avatar
That's an extremely big cam for a 5.3.
Old Dec 24, 2015 | 05:35 PM
Black'Rado's Avatar
Not much of an update, its been storming down here and i havnt cleaned a spot up in the shop yet to get it inside. but i did order some engine plates and the car shop solid mounts. should be here next week......but i leave the 29th back offshore so no updates besides parts ordering will take place until middle of january when i get back.
i may pick up a powerglide this weekend that ill have my local builder work his magic on. and then when i get home ill work on getting the motor and trans set in and mounted up and build a trans crossmember and drive shaft hoop. also i should be able to get my cage kit ordered and work on that as well.
Old Jul 3, 2016 | 01:12 PM
Black'Rado's Avatar
Long overdue update....changed jobs an been busy as hell with other things. But now ive sold some other toys and focused on the truck. changed m mind up on some things as time went on but its for the better. so here are some pics of newly gathered parts.....
wilwood manual master
speedway tubular uppers
solid lower bushings
lightweight column
ict billet motor plate
Size:  117.0 KBViking coil overs
TRZ rack an pinion
Hoosier 28x10s with only 1 burnout
Kirkey pro street drag seat
Glide fresh built with 1.80 straight gearset, turbo input, dual ring servo, t brake, deep pan, jw ultra bell, etc
cleaning out a spot in the shop an will be tearing into it. Ordering my cage kit an gona chop the front frame off and begin to fab that up...if anyone has pics of how theirs is setup that would be awsome. i picked up some 1 5/8ths DOM but thinking maybe stepping down to 1 1/2 stuff. Also got a mid plate on the way.
Old Nov 12, 2016 | 09:03 PM
Black'Rado's Avatar
Hadnt updated this in awhile so im copying and pasting from another board, i cant seem to get the pics to post it just shows a link....maybe someone can help me out mod or admin.
Got a few more parts in.... Also ordered a JD2 Model 3 bender and 1.5 180 degree die. 8ft stalk of 1.5 dom .095 wall, 8 ft of 1.5 .120 wall, 12x36 .125 sheet steel, and 4ft of 2x3 .125 wall rectangle tube. plan on using the .120 wall stuff for the new frame rails, the .095 stuff ill use for crossmembers and to mount my rack to. the 2x3 ill use for outriggers to tie my cage to frame.
anyways heres what i got in...soon some progress will be made besides stacking parts lol
Working on getting the new tank an fuel system in a customers trans am this week, once its gone ill have my spot open to roll the s10 in an really get under the knife on it!
but until then ive been collecting more parts and started work on the 8.8.
welding the tubes an started to cut the perches an sway bar mounts off
just a quick look at where i plan on cutting to shorten it
And got my Megasquirt MS3 Pro in along with a 7'' tablet to use for gauges and datalogging
oh also got a few more parts gathered up.....the assasian bars and perches, tci outlaw shifter, headgaskets,lifters, head bolts, an leaf sliders.
small little progress pics, been really busy so i only work on it one night a week it seems.
Old Nov 12, 2016 | 09:08 PM
Black'Rado's Avatar
Slowly making some progress, designing it as i go but so far its coming together kinda how i pictured it. Next ill be adding the grill mounts, headlight buckets, more bracing to hold overflow tank and maybe the stand alone fuel cell. Also started welding holes up on the firewall.
got my birthday present to my self in yesterday, ordered on april 14th....well worth the wait!
got the fronts mounted up when i had some free time at the shop, next ill get the 28x10 hoosiers monted up
Its been blistering hot and ive taken a break on the fab work for a little while.....but today i decided i had to do something!!
gona take em with me to work in the morning an spin em on the balancer, prolly get back to some fab work this week if it somewhat cools off...high 80s mid 90s at 5:30 is killer in the shop!
