Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Dec 15, 2006 | 12:19 AM
  #721
Bill Reid's Avatar
Originally Posted by moregrip
Bill, sup brother!
We will be degreeing the cam tomorrow. Ed Curtis has already address excessive cylinder pressure with this new bumpstick, it will handle 10-1 CR and boost no problemo
Cam specs you posted along with the MP122HH...
Keep the awesome pics coming!
Bill
Old Dec 15, 2006 | 08:13 AM
  #722
TurboGibbs's Avatar
My combustion chambers are 73.5cc's, -3cc valve reliefs, .008 in the hole, and as of now stock GM MLS gaskets. .054 is what I've seen typically used for compressed gasket height calculations. These rods are also 6.125
9.3-9.35:1 compression in case you didn't know already.
Old Dec 15, 2006 | 09:33 AM
  #723
zippy's Avatar
That should go pretty well with the low boost numbers. With all the parts you've picked I'm guessing that the 2.8" pulley should net about 10psi@6000rpm. The torque off idle should be rather impressive though.
Old Dec 15, 2006 | 01:24 PM
  #724
moregrip's Avatar
what a rush!
with the 2.8 it will be well over 10lbs of boost
Old Dec 15, 2006 | 01:32 PM
  #725
moregrip's Avatar
what a rush!
latest progress:
Old Dec 15, 2006 | 01:51 PM
  #726
TurboGibbs's Avatar
I think he forgot you have the MP122H.
Old Dec 15, 2006 | 02:07 PM
  #727
thunder550's Avatar
High on diesel fumes
I <3 his shirt
Old Dec 15, 2006 | 02:13 PM
  #728
zippy's Avatar
I remembered about the 122H. I was going from the numbers that the GTO put down. That was a pretty much stock 5.7L with a 2.9" pulley. Between the extra cubes, cam, headers, heads, etc, I'd expect at least a 1-3psi drop in boost over the GTO which would put him in at just over 10psi.
Old Dec 15, 2006 | 02:18 PM
  #729
moregrip's Avatar
what a rush!
only if it was converted to a 1 to 1 rear drive ratio and was running an 8" crank damper
Old Dec 15, 2006 | 02:22 PM
  #730
moregrip's Avatar
what a rush!
measured cam specs @ .050 came out to:
224/238.5 600/586.5 115.875LSA, 3.375 advanced
