Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Dec 14, 2006 | 06:55 PM
  #701
kbracing96's Avatar
Maybe I missed it, but how come you chose a flat top piston? Won't that increase your compression making it harder to run more boost with you larger blower? Just wondering?
Old Dec 14, 2006 | 07:00 PM
  #702
yurs78's Avatar
That's frigging Awesome!!! Thanks for showing us all of the little things behind the sceens (sp?)
With the pistons not having as much relief(somethings like 3cc right?) is that going to effect the comp ratio any? You said you wanted to be at about 9 with the new heads, will you still be around there?
How much boost will those rods and pistons be good for? Can they hold 20-24psi?
Keep up the good work buddy!
Russ
Old Dec 14, 2006 | 07:29 PM
  #703
2004SSS's Avatar
ok i think you just convince me to start building my motor, nice pics!!
Old Dec 14, 2006 | 08:06 PM
  #704
moregrip's Avatar
what a rush!
Thanks guys, done for today, finishing up tomorrow then headed home
night night
Old Dec 14, 2006 | 08:12 PM
  #705
so shiny......
Old Dec 14, 2006 | 08:22 PM
  #706
Wilde Racing's Avatar
How do I change this text
Damn there are some cool pics
Nice work Grippy
Old Dec 14, 2006 | 08:48 PM
  #707
Grippy's been playing us,He's really going with an 11.9to1 big cam NA setup.
Old Dec 14, 2006 | 09:02 PM
  #708
BADMOFO's Avatar
Cuz I AM a BADMOFO
Whitt, what's the word on the Big Whipple deal you were putting together?
Old Dec 14, 2006 | 10:05 PM
  #709
I just need to build or buy a pulley set up,I've been trying to talk to Whipple about their 10 groove setup.I'm hoping to get it together in January.
Old Dec 14, 2006 | 10:14 PM
  #710
moregrip's Avatar
what a rush!
I have a little more time know to address some of the questions/PM's I've recieved.
The Probe 4340 forged I-beams sold through WCCH run $375. They come with an ARP 7/16 bolt and are good for 800+ HP. They needed absolutely no machining and/or clearancing. Solid rods at a good price.
The rings were spec'd by Rex to live under 14-15lbs of boost (I'm sure they can hold more). The rings weren't cheap but he and Richard felt the extra $$ spent would be worth it in the long run. Apperently Ackerly & Childs has a fantastic reputation for making quality rings, personally I had never heard of them before.
We spent most of the day checking and rechecking all the clearances and cleaning/prepping the parts for assembly. I've gained a wealth of knowledge regarding good solid engine assembly practices, thanks Rex!
We are going to great length to make sure this motor holds together for years of good service. As a foundation, GM's Block and Crank where within excellent tolerance and again needed very little work here.
The flat top pistons are .008 in the hole so to high a CR will not be an issue. I'd actually like to see a little more and we may address this via head gaskets if time and availability permit tomorrow.
I think that's about it for now
