Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Sep 26, 2007 | 03:15 AM
  #1901
viciousknid's Avatar
Where's the Beef?
Come On Man. Put the camera down and pick up a wrench. Then pick up the camera again cuz i wana see this thing moving.
Old Sep 26, 2007 | 08:01 AM
  #1902
BigCountryx's Avatar
Originally Posted by moregrip
lol, I'm going to use as much of the stock tubing as I can to keep costs down
That's some funny **** right there
Old Sep 26, 2007 | 10:01 AM
  #1903
custom 68's Avatar
I agree
Old Sep 26, 2007 | 03:32 PM
  #1904
moregrip's Avatar
what a rush!
I was trying to figure out how to mount the Canton intercooler tank yesterday, spent the better part of the day modifying a factory auxiliary mounted battery bracket so the tank fits with no interference with the hood while maintaining full access to the drain valve and A/C connection........ rest assured, there is plenty of work being done; although I do appreciate your excitement
I think there's a good lesson to be learned here though.......mainly that things take longer than you anticipate.
Old Sep 26, 2007 | 03:45 PM
  #1905
rpav's Avatar
put together:
insert into space between damper flange and crank snout:
insert machined washer
secure with 180mm bolt
is this damper the standard or 10% overdrive?
thanks
Old Sep 26, 2007 | 05:35 PM
  #1906
moregrip's Avatar
what a rush!
thanks
it's 8" diameter vs the stock 7.5"
Old Sep 30, 2007 | 12:55 PM
  #1907
moregrip's Avatar
what a rush!
dexcool really seems to leave a lot of deposits in the cooling system, everywhere, the ID of the rubber hoses, overflow tanks, inside the radiator, pretty-much anywhere it flows. So far I have replaced everything besides the heater core and heater hoses. I will probably run this setup for a few miles and drain/strain the Evans coolant, then put it back in or replace it all-together........
makes me not want to put it into the intercooler system.....hmm
Old Sep 30, 2007 | 01:03 PM
  #1908
Stoichiometric's Avatar
If you are not worried about freeze protection than run distilled water/water wetter for the intercooler.
Old Sep 30, 2007 | 01:05 PM
  #1909
moregrip's Avatar
what a rush!
thats what I was running before with good results......
Old Sep 30, 2007 | 01:08 PM
  #1910
moregrip's Avatar
what a rush!
anyone run RMI-25 before?
http://arizonagn.net/how_to.htm
