Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Apr 2, 2007 | 05:10 PM
  #1221
Brains's Avatar
Guess what's back
Old Apr 2, 2007 | 05:28 PM
  #1222
moregrip's Avatar
what a rush!
woot woot! thanks brother!
Old Apr 2, 2007 | 05:53 PM
  #1223
dewmanshu's Avatar
Moderately Differentiated
you a pimpin now!!!
Old Apr 2, 2007 | 05:55 PM
  #1224
ZZebes's Avatar
I thought i was gonna have a heart attack
Old Apr 2, 2007 | 07:27 PM
  #1225
wkdivr's Avatar
Grip, check your PM's. You might have the same with your A/C problem as me.
Old Apr 2, 2007 | 07:29 PM
  #1226
trever1t's Avatar
2nd fastest 5.3 ECSB
What's the longest thread in PT.net history?
Yup i'm a whoring, mybad?
Old Apr 2, 2007 | 07:49 PM
  #1227
CHEVRACER83's Avatar
HEY MY PART NUMBER THREAD IS CATCHING GRIPPYS....
Old Apr 2, 2007 | 09:18 PM
  #1228
moregrip's Avatar
what a rush!
got to work on it some more tonight, gapped & installed some TR6 spark plugs, installed the stock coil brackets/coils, and installed some misc accessory pcs; also ran into a few issues I need to resolve:
tools to install power steering pulley:
First I cleaned out the 3/8-16 threads on the power steering shaft:
correct power steering install tool:
unfortunetly the bore diameter is larger on the stock pulley than the ATI so I will need to address this. Either ATI has a truck specific center piece or I will need to machine their piece to match the bore ID of the stock pulley, easy fix in either case:
Old Apr 2, 2007 | 09:25 PM
  #1229
moregrip's Avatar
what a rush!
test fitted some of the 8 rib stuff.
One issue I ran into is; my truck was equipped with the newer LS2 style truck water pump. The H/V Evan's unit is the old style truck water pump. If I want to run Magnusons latest accessory bracket I will need to clearance the backside of the bracket to get it to fit, otherwise the older bracket works just fine.
Here are some mock up pics:
so far all the 8 rib stuff is lining up perfectly, only need the power steering pulley and blower pulleys to finalize the fit (this is where you hope everything was machined correctly):
Old Apr 2, 2007 | 11:34 PM
  #1230
Steve Bryant's Avatar
LS1 Tech Veteran
Grippy,
It's all looking really good. I'm so happy that "Brains" found this lost thread. He's a great guy and does an excellent job of keeping Performance-trucks.net and LS1Tech.com going.
Steve
