Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Mar 29, 2007 | 08:21 PM
  #1141
bluecajun5.3's Avatar
11 Second Truck Club
once you have the bellhousing bolted down to the block and
as long as the bolt aren't too long, then i don't see a problem.
Old Mar 29, 2007 | 08:25 PM
  #1142
moregrip's Avatar
what a rush!
either the converter is not fully seated or the billet flexplate is dead-nuts accurate, I'm not sure which it is yet.........I did feel confident it was seated though
Old Mar 29, 2007 | 08:30 PM
  #1143
Bill Reid's Avatar
I would think if you can spin it... you're good
Old Mar 29, 2007 | 08:38 PM
  #1144
moregrip's Avatar
what a rush!
thats what I'm thinking too, but I don't want to leave it to chance
Old Mar 29, 2007 | 08:47 PM
  #1145
moregrip's Avatar
what a rush!
if it helps there is 7/8" distance from bell housing surface to TC mounting surface
Old Mar 29, 2007 | 08:56 PM
  #1146
wkdivr's Avatar
When I did mine(although it's a 60-E), I pushed the converter all the way in on the trans till it made a solid (clunk). When I put the trans in, the mounting points were about 3/16" apart. I just gently pried the converter out till the gap closed, and it went together fine. So far, so good, no noises, rattles, sparks........yet!
Old Mar 29, 2007 | 09:00 PM
  #1147
Richard@WCCH's Avatar
FormerVendor
If it spins freely with the bellhousing bolted up you should be good to go. Good work so far Grip.
Richard
Old Mar 29, 2007 | 09:03 PM
  #1148
moregrip's Avatar
what a rush!
Richard
good deal Richard, some of my thoughts are:
does the converter need to be fully seated other than to allow enough clearance to bolt her up, because ultimately it would be brought back off the fully seated position when torqued down. thoughts?
Old Mar 29, 2007 | 09:07 PM
  #1149
wkdivr's Avatar
It should be brought off it's fully seated position when you mate the converter, and flexplate, that way you don't put undue pressure on the pump.
Old Mar 29, 2007 | 09:08 PM
  #1150
Bill Reid's Avatar
I still think your fine ... especially since I am very confident you have the converter correctly seated in the tranny. You are a pioneer here... no one has your setup but once you are done I am sure others will follow I would give a shout to the flywheel and torque converter manu tomorrow morning. As long as nothing was forced... I still think you are golden! Carry on
Bill
