Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Mar 17, 2007 | 07:32 PM
  #1101
TurboGibbs's Avatar
Originally Posted by moregrip
question:
do I need to connect this back on the tranny or can I just cap the hard line on top of it?
Don't cap it. That is the tranny vent tube. If you cap it you will push fluid out your seals when it heats up.
Old Mar 17, 2007 | 07:33 PM
  #1102
TurboGibbs's Avatar
on the crank bolt you just need it to hold in there. 100lbs sounds good with some blue loctite.
Old Mar 17, 2007 | 07:37 PM
  #1103
ZR1 DREAMING's Avatar
On the crank bolt, I've done it atleast 9 times each with a new bolt and just tighten the fu@k out of it. Haven't had a problem.
Old Mar 17, 2007 | 09:22 PM
  #1104
moregrip's Avatar
what a rush!
that's what I was thinking but I may just end up tightening it real good as I don't have a 14mm hex bit, but I do have a 14mm hex key.
Old Mar 17, 2007 | 09:33 PM
  #1105
Steve Bryant's Avatar
LS1 Tech Veteran
Grippy,
Your truck looks good . . . even though the core is missing from the apple!
Thanks for the update,
Steve
Old Mar 18, 2007 | 12:50 AM
  #1106
Spoolin's Avatar
GFYS and STFU
Hmmm....how many people did it take to push that sucker back into the garage? Speaking of which what does a shell w/o a drivetrain weight?
Old Mar 18, 2007 | 11:18 AM
  #1107
yurs78's Avatar
hey grip, I just saw the pictures of the truck, it looks awesome! How many inches are the rims and do you have a lift under it? If yes how much? Thanks man! The relationships look great!
Old Mar 18, 2007 | 11:29 AM
  #1108
moregrip's Avatar
what a rush!
thanks bro, they are 20" wheels with 32" tall tires, pretty much stock ride height
Old Mar 18, 2007 | 12:02 PM
  #1109
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Red loctite and an impact has always got it done for me on the crank bolt.
Old Mar 18, 2007 | 12:08 PM
  #1110
moregrip's Avatar
what a rush!
I only have a 14mm hex key for my Hex Socket Head Crank Bolt, hopefully the local tool shack is open today, no luck at Home Depot or Sears.
