Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Jan 12, 2007 | 07:51 PM
  #991
2004SSS's Avatar
i know that but what size, i see you had the tap in them so im assuming they are bigger than stock sized.
Old Jan 12, 2007 | 07:54 PM
  #992
moregrip's Avatar
what a rush!
Ohhh.........., that is actually a thread chaser for the stock threads.
Old Jan 12, 2007 | 07:59 PM
  #993
2004SSS's Avatar
so they are still stock sized? they look bigger for some reason. thanks for the quick replies.
Old Jan 13, 2007 | 12:48 AM
  #994
GMC_DUDE's Avatar
The hole the chaser is in looks larger because it has a recess that holds a metal ring, which in turn holds the gaskets on while you install the heads.
Old Jan 13, 2007 | 03:07 PM
  #995
negativeswitches's Avatar
this what I used to clean up the block threads:
ARP Head thread chaser:
cleaning out all the threads:
for the rest of the threads to be cleaned:
i saw that earlier, i just want to know what size the threads are so i can buy one myself
is there a p/n for it?
thanks again and i must say good writeup thus far!!!
Old Jan 15, 2007 | 01:23 PM
  #996
moregrip's Avatar
what a rush!
ARP part#
912-0011
Clean Out Tap
M11x2.0-LS1
Old Jan 15, 2007 | 02:33 PM
  #997
moregrip's Avatar
what a rush!
While things have slowed down for me on the install front (due to work) I thought this might be something interesting to look at. This is the output the Dynosim software has my engine producing at 12 lbs of boost. All specs entered are actual. Don't forget to subtract a % for drivetrain losses and 5% for program variances:
Old Jan 15, 2007 | 03:11 PM
  #998
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Now we're talkin.
Old Jan 15, 2007 | 05:22 PM
  #999
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Looks like you should be solidly in the 600/600 range.
Old Jan 15, 2007 | 09:09 PM
  #1000
yurs78's Avatar
with that big of a cam how did the tq peak so low at 2500rpm? Regardless, that's awesome!
