Project 50 Shades LSXAP Shoptruck
Old Mar 17, 2016 | 09:19 PM
  #301
lsxperformance's Avatar
Happened on the 3rd spray pass I made on the big end of the 1/4. PTv was checked when I built it, it's no where even close. Was over .200 clearance iirc
Old Mar 18, 2016 | 01:00 PM
  #302
Vortec350ss's Avatar
Yea the cam that he had would have had all the clearance in the world.
Old Mar 20, 2016 | 11:16 PM
  #303
Out with the old stuff.. Cool **** is about to happen.
**Stand by**
And yes that is an actual really sketchy pic... I cut the last crossmember not thinkin about it and the truck flipped up and almost fell off the Jack stands. Nothing happened luckily just spooked me for a few minutes.. Figured I'd snap a pic quick to remind others to alway pay attention to what your doing.
Old Mar 21, 2016 | 07:53 AM
  #304
Atomic's Avatar
I have a gauge for that
Whoopsie!
Old Mar 21, 2016 | 08:15 AM
  #305
GMCtrk's Avatar
That just means you're doing good weight reduction
Old Mar 21, 2016 | 09:43 AM
  #306
Petraszewsky's Avatar
That's a self correcting action! Glad you're alright and nothing was damaged.
Old Mar 21, 2016 | 11:58 AM
  #307
Ya got lucky, I scored a 9" housing and axles and brakes. Got a smoking deal on it which was nice, for once.
Old Mar 23, 2016 | 08:11 PM
  #308
Sold the 10bolt and have some play money now.
Decided on a comp engineering 4 link, a diagonal bar, and anti roll bar, and I'm going to purchase and weld a back brace onto my 9". Haven't decided on shocks but I'll probly start with 150lb springs on the coil overs. Will be running a 430 gear for starters see how it works.
I removed my front sway bar and sold the stock bumper removed the cross member between the frame horns and am fabbing a hoop to replace the frame horns horns. Will have an SS plastic cover.
Old Mar 29, 2016 | 08:23 PM
  #309
Sat down an ran some numbers for gearing looks like to run 140mph trap speed on a 29" tire figuring roughly 20% slip should be around 7500 thru the traps with a 390 gear. I want to run a decently steep gear because I do a good bit of 1/8mile racing. So I'm going to give that a whirl. See how it goes, I dunno if I will need that much gear but I'll start there.
I bought some nice stuff: went with a comp engineering magnum 4link, magnum anti roll bar setup with adjustable links, and a diagonal link, a back brace for my 9" an upper and lower coil over mount, and a tubular driveshaft loop that I intend to use for the front mount for the 4 link and I will box the frame in and triangulate it.
I will be removing the factory lines I shoulda done that when the engine was out.. I also got a magnafuel 750 pump and pre and post filters, and a boost referencing regulator all magnafuel. I plan to start building the fuel cell soon been trying to source a sending unit, a filler that is vented that looks nice I came up with this one here. Should sit flush with the bottom of the bed. I also got hp tuners and plan to do the tune myself.
Old Mar 29, 2016 | 08:42 PM
  #310
Atomic's Avatar
If you have 20% slip at 7500rpm you need to throw that converter in the trash.
