Project 50 Shades LSXAP Shoptruck
Old Mar 9, 2016 | 09:10 PM
  #291
lsxperformance's Avatar
It fit with the new hood. I ordered a a/w intercooler kit from frozenboost.com I'm going to run the type 12 2000hp intercooler Bosch pump, heat exchanger a ice box. My turbo smart blow off valve showed up I bought the 50mm race port. I also purchased a leash boost controller and a bump box for my Trans brake. Couple more hours of work then i could probly start it up.. Probly be a couple weeks before it will be done enough T to drive
Old Mar 13, 2016 | 12:14 AM
  #292
So the intercooler setup shipped, I'm not sure exactly where I'm going to mount the intercooler. Me thinking either off the turbo, or under the radiator, I removed the crossmember under the radiator.
I also just bought my wheels for the rear, I just went with the weld Vitesse 15x12 with a 4.5"bs with a 4.75pattern. With champion bead locks.
Old Mar 14, 2016 | 10:42 PM
  #293
Ok I been trying to figure out what Ima do in the rear end. I think I have a plan and I'm probly gonna get flamed for it, but f it! Stock rear axles are 68" flange to flange I'm thinks about adapting my truck to a 9" robbed from a 4th gen f body. A local guy has one for 1700$ it's a moser 9" with a spool and 373 gear. It's 60" flange to flange and has piñon centered already. I'm gonna run a cell anyhow so I'll adapt the lower control arms, torque arms and springs to work in my truck so I have an easy suspension to adjust and modification with parts I can buy almost anywhere anytime. Yet the strength that I need to do work. And still light.
Old Mar 14, 2016 | 10:48 PM
  #294
GMCtrk's Avatar
What's your budget?
Got torque has bolt in 9" with strange pro hd case, 35 spline axles and locker for 3400
Old Mar 15, 2016 | 10:27 AM
  #295
Originally Posted by GMCtrk
What's your budget?
I could build it new for that $
Old Mar 16, 2016 | 12:24 PM
  #296
Intercooler showed up.. "2000 hp" rated a/w from frozenboost.com thing is huge! And weighs 35+lbs I hate to put it on the nose but really don't wanna run a bunch of piping. All over
Old Mar 16, 2016 | 12:34 PM
  #297
Atomic's Avatar
I have a gauge for that
Will it fit in the factory battery or air filter locations (the corners)?
Old Mar 16, 2016 | 07:48 PM
  #298
Nope it's huge I'm thinking Ima mount it where the gas tank is
Old Mar 17, 2016 | 08:06 PM
  #299
Random thing I figured out what happened to the 408. So Ima have the head checked/ repaired if needed. Head Dosent have any pitting just had a miss when cold and I suspect one of the valve was hit and is slightly bent.
Old Mar 17, 2016 | 08:07 PM
  #300
GMCtrk's Avatar
Ptv was checked??
