Preston129/BlkSlvrdo129 Build thread - TVS1900, EPS cam and more
Old Jun 26, 2011 | 02:29 AM
  #151
j_ahlheim's Avatar
Updates? Dont leave us hanging now Preston
Old Jun 26, 2011 | 08:32 AM
  #152
Preston129's Avatar
Haha, I wouldn't do that! It's been raining the past 2 days so my progress has been limited.
Friday I dropped off the rest of my exhaust for powdercoat, and yesterday I ran all the water lines for the intercooler, cleaned up some wiring harnesses, got the rad and fans back in. Reconnected the tranny lines and rad hoses, so all that's left is to install the Lingenfelter MAF, connect the intake tube, swap the throttle body over, fill it with coolant, download the tune and then I can fire it and pray it works lol.
I'll post some pics a little later, going out to do some work now.
Old Jun 26, 2011 | 01:06 PM
  #153
pewterliftedz's Avatar
cant wait to hear her runnnin
Old Jun 27, 2011 | 05:40 AM
  #154
Preston129's Avatar
Well it fires, but won't stay running. Idles at 1000 for about 5 secs, then lowers to around 500, then dies, all in about 10 secs. RPMs don't move if I try giving it gas either.
Any ideas? I don't know what the idle RPM is set at (if changed at all) but I'm going to datalog the attempted start and send it to Justin (Blackbear) this morning. Because it seems to idle well at 1000, it's just when it drops to 5-600 that it dies. So I'm not sure if it's following the same idle RPM points as stock, or if something is making it drop RPM.
Oh, and it's INCREDIBLY loud. Surprised even me, and I've worked on 8 sec cars before Guess open headers will do that
Old Jun 27, 2011 | 07:28 AM
  #155
Atomic's Avatar
I have a gauge for that
Does it smell overly rich? I'm guessing injectors data is way off. How easy does it start?
Old Jun 27, 2011 | 07:32 AM
  #156
Preston129's Avatar
Starts very easy, first crank of the key. Yes it smells rich, but it's only on for 5-10 secs and I didn't know if it was just because of the open headers and no cats.
I'm going to grab the datalog now and I'll also record the startup.
Old Jun 27, 2011 | 09:11 AM
  #157
Preston129's Avatar
Doesn't show much, but here's what I'm dealing with at startup:
[youtube]BsRbBSwy5ow[/youtube]
Old Jun 27, 2011 | 12:46 PM
  #158
j_ahlheim's Avatar
not excatly what you were expecting on first start up but you did change alot of things with the cam, maf, blower, etc I'm sure there is just a bug in there somewhere. Your in good hands with Justin. Keep us updated I know I got my fingers crossed for you.
Old Jun 28, 2011 | 01:34 PM
  #159
Holty's Avatar
Notorious BIG
how many times have you tried to start it up since loading the new tune?
mine does that every time i flash a tune, takes 3 or 4 tries before it starts and runs
Old Jun 28, 2011 | 03:11 PM
  #160
Preston129's Avatar
I think I've tried starting it either 4 or 5 times in total, but the second day (when I took the vid) I re-flashed the modified tune just to convince myself that it was 100% changed and wasn't something I did. So since that relflash, it's only been attempted to start once.
But the first day I was starting it, it didn't seem like it was trying any harder to stay running on the last crank than it did the first time I tried.
Maybe I should try that to see if the PCM will learn to idle correctly with the cam and injectors.
But would the engine learn to idle higher? Or would it still try to drop down to 600 RPM? Cause that's where it dies on me.
