Petro's Project ERL Superdeck 427 w/ Whipple 2.9L
Old Nov 2, 2017 | 12:44 PM
  #491
arthursc2's Avatar
Wow, 755hp in the mustang with the blower and tuning
I may have to switch platforms.......
Old Nov 2, 2017 | 02:10 PM
  #492
Petraszewsky's Avatar
Yeah the Whipples in the Mustangs make crazy power. Compare the 2.9 in a coyote vs ls and the coyote wins
Old Nov 2, 2017 | 04:30 PM
  #493
Zoom zoom
Petro's Project ERL Superdeck 427 w/ Whipple 2.9L-uww6aa1.jpg
Old Nov 26, 2017 | 11:50 AM
  #494
Coated intercooler
Petro's Project ERL Superdeck 427 w/ Whipple 2.9L-ymeh4le.jpg
Petro's Project ERL Superdeck 427 w/ Whipple 2.9L-b3biuum.jpg
With spacer...still have to finish polishing it
Petro's Project ERL Superdeck 427 w/ Whipple 2.9L-uu5an2c.jpg
Old Nov 26, 2017 | 04:00 PM
  #495
I used my vacuum former as a small downdraft table since the core is so thick and dense. I placed a trashbag over it to seal the vacuum former off and had the intercooler poking through. It pulled the coating straight through. There wasn't any coating on the vacuum former top so it all had to of coated the intercooler.
The coating works!!! I did simple before and after tests. Before: intercooler temp 70* / ice water temp 35*....filled with ice water and watched surface temps for 2min...58*.....After: intercooler temp 70*/ ice water temp 35*...filled with ice water and watched surface temps for 2min...45*
Old Nov 26, 2017 | 04:59 PM
  #496
03sierraslt's Avatar
What’s the Coating? How hot is it rated for?
Old Nov 26, 2017 | 05:12 PM
  #497
Boron Nitride and it's good to like 2500*F I believe. It's used as a mold release for molten metals. It also has very high thermal conductivity. It's used as welding paint and in pastes for heat sinks along with many other applications. You can spray it on a body panel and weld in a patch without fear of heat warping it. It dissipates heat and cold very readily/quickly.
Old Nov 26, 2017 | 06:39 PM
  #498
skolman91's Avatar
This stuff has no chemical interactions, meth, oil etc..?
Old Nov 26, 2017 | 07:57 PM
  #499
I coated a piece of metal and sat it in used motor oil for a week and then sat it in acetone for a week. None of the coating came off by itself in oil or acetone but if you rubbed it then it would come off. However, if you rub it after it's cured then it comes off fairly easily as well. It's a very thin easily scratched coating but is basically non reactive/inert to chemicals.
I have Cerakote Heat Dissipating coating coming this week which is a much harder coating.
Old Nov 26, 2017 | 10:17 PM
  #500
Vortec350ss's Avatar
interesting... so it will just rub right off?
