Oakley's History Lesson and Build Thread
Old Mar 12, 2014 | 03:27 PM
  #511
oakley6575's Avatar
You'll be good for around 500hp with the 255. I have a ractronix drop in bucket assembly with a walbro 255 if you want it. I bought it and used it for 500 miles before I switched to the 450.
Old Mar 12, 2014 | 06:45 PM
  #512
silverado.408's Avatar
(Taking notes.) Killer build.
Old Mar 24, 2014 | 07:44 PM
  #513
oakley6575's Avatar
Thanks bud. I'm taking notes from you too. I need to relocate my shocks like yours sometime soon.
Old Mar 24, 2014 | 07:56 PM
  #514
Its not that hard just took measurement's leveled the truck took more measurements then said screw it and started welding. Then just made sure I had a slight backward lean on the shocks I think it was like 5 degrees. Just need to call Viking for the hook up. This kit has everything needed http://www.summitracing.com/parts/hal-mt100k/overview/
Old Mar 24, 2014 | 07:57 PM
  #515
I think I missed it did you remove all evap ? I'm doing that tomorrow. Based on a little chat with Atomic on his setup.
  #516
oakley6575's Avatar
Got the wheels in today. I had discount mount and balance one and leave me the other wheel for mock up. I need to get some S10 calipers asap and have my buddy machine them down for me. Then I can set the wheel on and see where grinding is needed.
I took the truck out to the street drags last weekend and it **** on me for the first time. First run, i ran 12.63 (i think) with the same 1st to 2nd shift problem. I had the shift point down around 4400rpm and it still over revved and I had to let out. Second run I got in the staging lanes and I watched the temp gauge go to 200, 210, 220, 230, 240, WTF. The fans quite on me and I couldn't get them back on to save my life. HPT wouldn't command them on, couldn't find a bad relay/fuse/wire ect. So I let it cool down and drove it home. It is mostly all freeway to the shop so it never got hot.
Turns out all I needed to do was disconnect the battery. I pulled the fan harness out, and everything was fine. Just needed a hard reset The track outings are getting more and more frustrating. I have been out there 3 times so far and still haven't gotten a clean run. I just fight the trans everytime. Next time out I'm just going to try and manually shift it and see what it does.
Anyways, I'm waiting for my aeromotive fuel filter to ship so I can start on the fuel system and intake swap. Before I do that, I'd like to get the truck on the dyno and see what 13psi is producing.
Old Mar 24, 2014 | 08:36 PM
  #517
oakley6575's Avatar
Not yet, but I will be when I do the fuel system
Old Mar 24, 2014 | 08:43 PM
  #518
I like those wheels do you have a part number ? In comparison to stock 17 do you think these are heaver ?
Old Mar 24, 2014 | 08:44 PM
  #519
GMCtrk's Avatar
Which fan harness are you using?
Old Mar 24, 2014 | 09:05 PM
  #520
oakley6575's Avatar
They are custom built cragars. They don't make the 15x10 with a 6.5" backspace so I had to special order them. They are the 342 D window series.
OEM. I tore it apart and checked all the wiring. Nothing was melted or shorted so I threw new loom on it and called it a day.
