Oakley's History Lesson and Build Thread
Old Oct 20, 2013 | 11:57 AM
  #171
oakley6575's Avatar
Originally Posted by Chevy_King1500
almost there! what's left? cold side? injectors?
when you get your DP in check the fit on the fire wall, mine seems to be hitting like half way down where there's a pinch weld. it's not hurting anything just annoying because you can here it in the cab and the passenger can feel in through the floorboard
when I do gaskets and studs this winter I'll take care of it, few hits with the ballpeen should do the trick
Well I couldn't ever find a t4 gasket in my kit so I will have to either find one locally or order one while I'm out of town this week. I just need to mount the turbo, downpipe, intercooler, and cold side. So once the intercooler is mounted, it should be a cake walk. I was going to try and start it last night without an intercooler but remembered I didn't have a gasket for the turbo
I probably won't have time to work on it today so I will have to finish up this install next weekend.
Old Oct 20, 2013 | 06:21 PM
  #172
Choda's Avatar
I think my t4 gasket was in the clear bag the turbo came in
Old Oct 20, 2013 | 06:26 PM
  #173
Choda's Avatar
For the feed line get a angled fitting and screw it into the stock cover then attach ur line to that. Summit has them
Old Oct 20, 2013 | 10:38 PM
  #174
Blown06's Avatar
8 Second Truck Club
fuel press regulator mounted to firewall is a no no regarding track tech. Not sure if your worried about that though. Just a heads up..........nice work.
Old Oct 20, 2013 | 10:40 PM
  #175
Atomic's Avatar
I have a gauge for that
I would highly suggest running the dust cover for the trans.
Old Oct 21, 2013 | 07:17 PM
  #176
Why is this? Mine is laying on the shelf in the shop.
Old Oct 21, 2013 | 07:56 PM
  #177
Chevy_King1500's Avatar
keeps mud, dust, grit from getting inside the trans
Old Oct 21, 2013 | 08:12 PM
  #178
Atomic's Avatar
Adds a lot of support for the trans to the engine and will keep the heat of the crossover off the converter.
Old Oct 26, 2013 | 08:30 PM
  #179
oakley6575's Avatar
A 45 degree fitting would be perfect.
Yea this definitely isn't a track truck but when the time comes, I will move it. Probably when I get fuel rails and swap in a -8 feed.
I really need to get one. Been on my list for the past few years
Old Oct 26, 2013 | 08:53 PM
  #180
oakley6575's Avatar
Today I had a few hours and pretty much buttoned it up except for the damn turbo gasket.. I went all week and forgot to order one. So I guess this week I will get a gasket and be done. Just need to run some vacuum lines and put the boost gauge in.
