Next stage of the build
Old Oct 11, 2007 | 08:29 PM
  #41
leftcoast32's Avatar
FormerVendor
Race Gas burns real nice and clean.
Old Oct 11, 2007 | 10:01 PM
  #42
BlownChevy's Avatar
blownerator
25 Year Member
Looking good Joe....I am sure you will be added to the list of big HP Maggie guys!
Old Oct 12, 2007 | 09:26 PM
  #43
FormerVendor
I was able to get the Cam installed today. I had to convert the Cam Timing Gear to the older style 3 bolt from the new single bolt design. Lingenfelter sells the kit if you need it.
I also tested the heads for Piston to Valve Clearance. I was getting interference with the Intake Valve and the edge of the Intake Valve Relief in the pistons. I will have to work on the pistons to gain the clearance necessary.
Old Oct 13, 2007 | 02:24 AM
  #44
rpav's Avatar
u wanna come do mine when your finished
Old Oct 13, 2007 | 08:22 PM
  #45
FormerVendor
I was able to get the work done to the Valve Reliefs in the pistons. Checked everything again and all the clearances are perfect. Then I installed the new Cometic Head Gaskets and the L92 Heads. I need to reinstall all the ARP Head Studs and double check the pushrod lengths one more time.
Old Oct 13, 2007 | 08:41 PM
  #46
BlownChevy's Avatar
blownerator
25 Year Member
those are some purdy heads you got there.
Old Oct 13, 2007 | 08:48 PM
  #47
FormerVendor
Thanks!! Richard and the crew at WCCH did a great job on these heads.
Old Oct 13, 2007 | 08:50 PM
  #48
moregrip's Avatar
what a rush!
sweet, how did the cutting go, which bits did you end up using? and where are the pics yo?
Old Oct 13, 2007 | 08:56 PM
  #49
FormerVendor
I ended up using the bit that I purchased at Sears yesterday. It made the cleanest cut. It took longer to tape everything up then it did to cut the intake reliefs. I would have taken pictures but you cant tell it has been done. I used a caliper and marked them .050 off the current radius and then cut and sanded them one at a time.
Old Oct 13, 2007 | 08:59 PM
  #50
moregrip's Avatar
what a rush!
good deal, glad it all worked out well for you
