Next stage of the build
Old Feb 1, 2008 | 08:43 AM
  #141
leftcoast32's Avatar
FormerVendor
Originally Posted by rpav
who makes those breathers? did you end up leaving both on?
I purchased the breathers from Speed Inc off of E-bay. I still have them on and used a passenger side valve cover on the drivers side to mount one also.
Old Feb 12, 2008 | 08:50 PM
  #142
FormerVendor
I received the Final Billet Aluminum SuperCharger Pulley's today in 3.2 and 3.1 sizes for the TrailBlazer SS. I polished the 3.1 and installed it to see what the boost would be. It is now a solid 17 psi of boost at redline.
Old Feb 12, 2008 | 09:11 PM
  #143
supersub's Avatar
Real Nice Joe!Really like the look.
Old Feb 12, 2008 | 09:13 PM
  #144
FormerVendor
Thanks Brother!
I cant wait to see your LSX 427 with Boost!!!
Old Feb 12, 2008 | 09:31 PM
  #145
supersub's Avatar
Originally Posted by 2005SSR6Speed
Thanks Brother!
X2
Old Feb 12, 2008 | 09:36 PM
  #146
supersub's Avatar
I would like to see a 10 rib anodized version,Figure i could make a little room for it.
Old Feb 12, 2008 | 09:37 PM
  #147
FormerVendor
Here is another picture
Old Feb 12, 2008 | 10:58 PM
  #148
MikeGyver's Avatar
Originally Posted by Spoolin
Bejessus, how big is that intake tube? Looks like 6 inches!
And is it pieced together from elbows and straight pieces that maybe somebody else could use to make their own custom intake, or is it molded in one piece?
Old Feb 12, 2008 | 11:17 PM
  #149
yurs78's Avatar
Flat out awesome!!! Great work and ATD. Love to see some video of that bad boy in action!
Old Feb 13, 2008 | 08:40 AM
  #150
FormerVendor
This was posted on another site. This is what is used to assemble the Intake Tube.
You will need the below items and a few clamps. I cut 1" off of the 4" diameter Hump Hose and then joined all of the with 4" aluminum tubing inside of the joints. This way when assembled you dont see anything except the rubber tubing. Once everything is mocked up and the angles are all correct use Indutrial Superglue and bond all the joints with a section of aluminum tube inside each joint. When you are cutting the rubber tubing make sure to use a razor knife, dip the razor knife in a cup of water and it will cut the rubber much easier.
http://store.airflo.com/rubber-hoses---clamps.html
(1) K&N E0773 (you will insert a 4" long section of aluminum Tube into the filter)
(1) Rubber Hump Hose 4"
(1) Rubber Intake Elbow Short Radius 90 Degree 4"
(2) Rubber Intake Elbow 45 Degree 4"
(1) Reducing Hose Insert 4" to 3.75" (only if using the stock MAF)
(1) Reducing Hose Insert 4" to 3.5" (only if using the stock MAF)
(1) 12" section of 4" Diameter Aluminum Tubing
They also have some very nice Stainless Steel Band Clamps that I use. If you are using the Ligenfelter 100mm Maf it will fit perfectly in the intake tubing and you will not need the reducing hose inserts.
**You will need to cut the aluminum into (3) 4" long sections.
