Next stage
Old Oct 3, 2017 | 09:15 PM
  #271
MikeGyver's Avatar
Wow, a driveway long enough to get up to at least 70 mph.
Old Oct 4, 2017 | 10:13 AM
  #272
TXsilverado's Avatar
I was thinking the same!
Old Oct 4, 2017 | 10:32 AM
  #273
03sierraslt's Avatar
My driveway is 1/8m
I would never do that on the street.
Old Oct 4, 2017 | 11:28 AM
  #274
M60gov20's Avatar
My driveway is 1/8m
So you didn't plan ahead enough for a shut down area at the end? Is it concrete? I could see me getting in trouble for marking up the concrete if I had a drive like that. Truck sounds awesome! I'm getting pretty excited about doing my 1900 and cam soon.
Old Oct 4, 2017 | 12:01 PM
  #275
There maybe some sarcasm in that post guys. But my driveway is right around 1/8m, I live in the country.
Old Oct 10, 2017 | 06:40 AM
  #276
Well I put the 2.6” on and have been working on the tune, it’s strong. I am seeing right around 18psi. The Holley 105 and 5” intake are working great, I’ve had it to 6700rpm@18psi and solid boost no signs inlet restriction now. That’s as high as I’ll spin it with the 2.6” as I don’t want to spin the blower any faster. 6700 actually feels about right for the 2.6, when I had the 2.8 on I had it to 6950 and it felt close to peak.
On another note, been chasing another issue. My trans temp gauge quit working in my cluster so I need to get that fixed. I swapped the stepper motor but it’s still not working. I can make it do a gauge sweep with a tech2 but it won’t read. I think something on the board is messed up. Gonna swap in another cluster to see.
Old Oct 10, 2017 | 09:23 AM
  #277
Vortec350ss's Avatar
Bust out that GoPro!
Old Oct 10, 2017 | 10:11 AM
  #278
1FastBrick's Avatar
Custm2500's Rude Friend
If the gauge sweeps with the tech 2 the issue is not the gauge. It's either a loose pin or the internal sensor on the trans.
BTW, I ******* hate this mobile version!!!
Old Oct 10, 2017 | 11:39 AM
  #279
Already checked the sensor, swapped another harness to vehicle harness and heated fluid sensor with heat gun and scanner shows temp but gauge doesn’t move.
Old Oct 10, 2017 | 04:28 PM
  #280
Last Call's Avatar
TOTM: January 2007
18 pounds must feel great. You have that Maggie putting in some work!
Are you experiencing any belt slip?
