My large frame front mount project with two videos
Old Feb 21, 2009 | 08:02 AM
  #161
SimpleManLance's Avatar
looks great, keep up the good work!!! your welds look amazing would you be interested in making me one too? your craftsmanship is 2nd to none.
Old Feb 21, 2009 | 11:25 AM
  #162
Wilde Racing's Avatar
How do I change this text
lol... yea, I thought that picture would raise a few eye brows...
I started bending my oil cooler lines today. I hope to do a bit of welding later today...
Old Feb 21, 2009 | 11:44 AM
  #163
vanillagorilla's Avatar
OMFG! WTF is that? Where did you get that pic? That things would go off like a bomb once the exhuast pressure builds.
Old Feb 22, 2009 | 08:08 PM
  #164
A real update.....
Got the manifold welded up. though it far from done. a little bit more smoothing and some minor port work is needed. Then it will be wraped up..Thank god, because this has taking A LOT longer than I had though....
Anyway.. Picture
I had to cut the drivers bank off in order to weld it all up, here is a pic of the passenger bank pretty much done...
Drivers bank welded up and back in to position. With a coat of black muffler anti rust..
And just wanted to see if the stupid manifold would hold the pig of a turbo.... "Look ma, no chain"
Next week, I hope to have the down pipe done and finish up the cross over, and maybe a little section of the exhaust.
Old Feb 22, 2009 | 08:14 PM
  #165
It will for now, but add repeated heat cycles, and fatigue will come sooner. Consider a brace of some type. Once it sags, things tend to get ugly quickly.
Looks good though. How much room for the down pipe now?
Old Feb 22, 2009 | 08:23 PM
  #166
Plenty of room .... I think, Yes a support system is Defiantly in the plans. I just need to figure out my waste gate location. I plan on using accy bolt holes in the front of the head, and possibility the a/c compressor pump mounting bolts....
Old Feb 22, 2009 | 08:25 PM
  #167
built408's Avatar
looks good, nice work! What size downpipe are you going with?
Old Feb 23, 2009 | 12:03 PM
  #168
The plan is 5 inch.... Even if I have to it to fit
Old Feb 23, 2009 | 05:16 PM
  #169
built408's Avatar
with a big hole saw, it comes out of the hood pretty easy
Old Feb 23, 2009 | 08:42 PM
  #170
