My large frame front mount project with two videos
Old Feb 25, 2009 | 12:09 AM
  #171
Wilde Racing's Avatar
How do I change this text
Default It fits!!!!!!
Well , made a little bit of head way... Got the cross over tacked, and the down pipe tacked....
YES it fit, it is not touching ANYTHING right now, but I'm defiantly going to have to make a little bit of room for it to move around...
Crossover...
The plan for the waste gate..
I'm pretty sure you (you know who you are) were right, 5 inch is way too big
Old Feb 25, 2009 | 08:45 AM
  #172
kbracing96's Avatar
Looking good there Dusty You got enough hot pipe for about an 800ci motor though,
Old Feb 25, 2009 | 08:51 AM
  #173
ChevyTruck's Avatar
something else
Do a body lift and that will give you the clearance that you need to get that 5" pipe down there.
Looking awesome!
Old Feb 25, 2009 | 04:29 PM
  #174
UBLUZIN03's Avatar
WOW! Thats awsome..Nice work.
Old Feb 25, 2009 | 08:00 PM
  #175
dkota1968's Avatar
5in exhaust is just insane, i like it. Good luck on the out come!
Old Feb 25, 2009 | 08:14 PM
  #176
Just Enough's Avatar
Looks good.
Old Feb 25, 2009 | 08:15 PM
  #177
Stoichiometric's Avatar
Sorry wrong user name. Looks good Dusty.
Old Feb 25, 2009 | 08:45 PM
  #178
Mangled03gmc's Avatar
Baltimore Whore
Looks killer man, great work...
Old Feb 25, 2009 | 09:52 PM
  #179
Thanks guys... I'm trying to come up with the exhaust plan after the down pipe. I plan on mounting the 3 inch cut out right at the bottom of the down pipe. then running 5 inch all the way back to the muffler area, then going to 4 inch and threw a muffler, then over the axle and out near the factory location all with 4 inch.
OR
Run five to about the middle of the cab, slit into two 3 inch pipe and run the outlets behind each wheel. Each 3 inch would have it's own muffler.
I would have to buy all the 3 inch as well as two three inch mufflers. If I did the 4 inch I already have all the pipe I would need, I would just a muffler. I would like it to be quite-ish..
Old Feb 26, 2009 | 06:22 AM
  #180
dewmanshu's Avatar
Moderately Differentiated
you said quite-ish
