Lets Try This Again: 410-PT88-80e
Old Jan 2, 2011 | 07:47 PM
  #241
Atomic's Avatar
I have a gauge for that
I have a TCI flexplate which is thicker and reinforced around the hole so that takes away some of the engagement of the bolts.
Old Jan 2, 2011 | 07:54 PM
  #242
1Bear's Avatar
Those measurements are with my PI converter and TCI flexplate. I’m not saying it’s identical to yours, but does stand a good chance of it, assuming you still have a PI converter as well. If you switched to another brand, there is no telling what length you will need for proper engagement.
Old Jan 2, 2011 | 08:20 PM
  #243
Atomic's Avatar
I have my PI...but looking at the threads in the converter with a mirror it only looks like the bolts went less than half way into the converter...
Old Jan 2, 2011 | 08:25 PM
  #244
1Bear's Avatar
Yours may have different lugs welded on than mine, beings mine is a couple of years old. Who knows, all you can do is measure and use what’s appropriate.
Old Jan 2, 2011 | 08:38 PM
  #245
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If youve got a set of calipers you can just use depth checker part of it and figure out what you need really easily.
Old Jan 3, 2011 | 06:42 PM
  #246
Coban's Avatar
So, in the inspection cover picture I see the 3 TC bolts, but what are the other 2 chunks of metal?
Old Jan 3, 2011 | 07:43 PM
  #247
Atomic's Avatar
Good news, got it running again today. I ended up using some 20mm bolts and shimmed the converter 2mm since it was at the upper limit of allowed separation from the pump, also put a dab of blue loctite on the bolts. A few turns with a thread tap cleaned up that one hole enough to get the bolt going. I drove around for a while, then took the cover back off and retightened everything just to make sure.
I also figured out what that horrible scratching noise was...appearently there was a clearence issue with the inspection cover...good thing its soft metal I suppose... I dremeled some more away just in case.
The little chunks in the inspection cover is actually a piece of the oil pan that a bolt hit. If you look directly behind the bolt in this picture you can see where it broke off.
So far I feel like ive gotten really lucky...
Oh and here is my finished exhaust...I think I may try to find a stock duramax muffler to put there since its still louder than I would like with the two magnaflows.
Old Jan 3, 2011 | 11:32 PM
  #248
Spoolin's Avatar
GFYS and STFU
Is that your cut-out? What happens when you close it? Where does it dump?
Old Jan 4, 2011 | 01:46 AM
  #249
Atomic's Avatar
Yes...when I close it it goes through the mufflers, when I open it it just dumps straight out
Old Jan 4, 2011 | 04:42 AM
  #250
Spoolin's Avatar
GFYS and STFU
The angle of that pic screwed me up...I wasn't able to see the Y at first!
