Lets Try This Again: 410-PT88-80e
Old Jan 1, 2011 | 10:02 PM
  #221
charcold-bowtie's Avatar
that really sucks a fat nut.
Old Jan 1, 2011 | 10:18 PM
  #222
Atomic's Avatar
I have a gauge for that
I was right, found this little present in the inspection cover
Old Jan 1, 2011 | 10:25 PM
  #223
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
TC bolts? Thought you got that figured out?
Old Jan 1, 2011 | 10:26 PM
  #224
MikeGyver's Avatar
Great luck. Now you can get a race flywheel.
Old Jan 1, 2011 | 10:31 PM
  #225
Atomic's Avatar
I did...problem is number 1.) no way in hell am I putting threadlocker on the tc bolts after rounding one off trying to get it out this summer when I was doing my 408 swap. And with the TCI flexplate im using, I need longer bolts to go deeper into the torque converter since these obviously dont go far enough, and since the plate is thicker it sits too close to the rear cover bolts without having to grind the head of the torque converter bolts...so what I really need is some longer bolts than have a torx head or something that wont round off with a short head in grade 8 or stronger...
I am really hoping the threads on the converter arent trashed. Does anyone know the thread size off hand?
Old Jan 1, 2011 | 10:51 PM
  #226
custm2500's Avatar
Ph.D. in HUBRIS
WOW!
You are really trying to scare me from building a stroker. I have aways been fearful of all of the problems you can run into building a stroker. Parts of you build makes me feel confident, then you drop bombs like this. I sure hope this is the only problem with the new set up and that it becomes a simple easy fix of just needing new bolts.
I am sure you know but they do make a few different strengths of lock tight.
Old Jan 1, 2011 | 11:19 PM
  #227
Atomic's Avatar
I hope so too. I am going to go to fastenal on monday and see what they have. Looks like I need a 20mm length in 10x1.5mm thread with a small head on it...
...and by the way, I took off the boost reference line on the wastegate which basically doubles the spring pressure, and 13lbs at 15 degrees is somewhere between holy **** and oh my god
Old Jan 1, 2011 | 11:41 PM
  #228
MikeGyver's Avatar
I still have stock converter bolts, which are button-head allens.
Old Jan 1, 2011 | 11:49 PM
  #229
Atomic's Avatar
Cool....the stock ones seem too short for the tci flexplate so I am going to find some longer ones
Old Jan 2, 2011 | 01:32 AM
  #230
Bumpers's Avatar
You should be good at pullin transmissions by now
