Lets Try This Again: 410-PT88-80e
Old Dec 20, 2010 | 05:02 PM
  #131
Bigredmariner's Avatar
Good news, I've been reading the thread but haven't commented yet. Great looking engine I hope you have better luck with this one.
Old Dec 20, 2010 | 05:17 PM
  #132
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Good deal, you might want to make sure the converter is engaging the trans pump fully, some of the PI converters need to be shimmed.
Old Dec 20, 2010 | 06:02 PM
  #133
Atomic's Avatar
I have a gauge for that
It is engaged more with this flexplate than it is the stock one (flexplate). I am using the stock converter at the moment.
Old Dec 20, 2010 | 06:17 PM
  #134
1989k1500's Avatar
Originally Posted by Atomic
Also, that little coolant blockoff thing on the back of the passenger head is leaking pretty fast, call it a fast drip, so I am about to pull the intake to see whats going on.
Mine did that when I put the 6.0 in. I tightened them and it stopped leaking. The next time I had the intake off I replaced those gaskets though.
Old Dec 20, 2010 | 06:25 PM
  #135
Atomic's Avatar
Good to know. It was tight on there, thats whats weird....maybe I put the gasket on backwards? I grabbed one off of my 5.3 and put a thin layer of rtv on it, and im about to go try it now...
Old Dec 20, 2010 | 07:46 PM
  #136
Atomic's Avatar
Got that plug squared away and went driving around. Its weird giving an engine a lot of throttle and going fast, but not hearing a whine
I really need a higher torque converter for this setup NA. Off the line is such a bummer, but man it pulls hard after that. Should be downright sick with the turbo. My 408 tune was pretty close to this one actually, so after a couple flashes my trims and PE fuel is pretty close. I am running at most 22 degrees of timing, havent touched it from my 408 tune actually, no need to break **** just yet
Old Dec 21, 2010 | 01:26 PM
  #137
Atomic's Avatar
More toys...
New 5" dshaft should be here Monday or Tuesday, and I should have everything together by then
Old Dec 21, 2010 | 07:20 PM
  #138
1989k1500's Avatar
Nice!
Old Dec 21, 2010 | 07:47 PM
  #139
Bumpers's Avatar
You can deliver my d shaft if you want lol
Old Dec 21, 2010 | 09:56 PM
  #140
Atomic's Avatar
Is cole not buying your cam anymore?
