I'm the first on my block
#21
Im gonna save you some time "Build a new inlet use the original blower flange only".Or buy mine its ported to 96mm right now you could probably get 100mm out of it.Im changing mine again "Think twin 90's i got to one up ya man."
#22
the whipple is a great s/c i actually knew a guy down here that was running one for years on his 5.3L but he switched to a tvs 1900 or 2300 cant remember. the only down side is that they dont replace the intake.
off topic but ive seen that kenne bell makes a s/c for the ls based engines, but ive never seen anybody run it, looks clean.
#23
make a new intake track! With the whipple being a compressor you need to have as much air going in as you can.
Trick made one for a lightning.
Double 78's would be cool looking. DOuble 90's and I bet you are at max for the head unit.
#27
That's the most polite way that I've ever heard of saying that my welding sucks. I know, but I'm cheap. It's welded inside and out. A little leakage instead of drilling the throttle plate? Don't worry, it will be invisible after a little flat-black paint.
#29
I took a pic to show that the working side looks a lot better than the outside:
And I made a video to show how it sounds now:
http://www.youtube.com/watch?v=SGdFb7g7ZUQ
