I'm the first on my block
Old Mar 18, 2010 | 12:01 AM
  #21
SincalT/A's Avatar
Im gonna save you some time "Build a new inlet use the original blower flange only".Or buy mine its ported to 96mm right now you could probably get 100mm out of it.Im changing mine again "Think twin 90's i got to one up ya man."
Old Mar 18, 2010 | 12:14 AM
  #22
silveradoman's Avatar
Registered User
the whipple is a great s/c i actually knew a guy down here that was running one for years on his 5.3L but he switched to a tvs 1900 or 2300 cant remember. the only down side is that they dont replace the intake.
off topic but ive seen that kenne bell makes a s/c for the ls based engines, but ive never seen anybody run it, looks clean.
Old Mar 18, 2010 | 09:21 AM
  #23
OnyxSilveradoSS's Avatar
make a new intake track! With the whipple being a compressor you need to have as much air going in as you can.
Trick made one for a lightning.
Double 78's would be cool looking. DOuble 90's and I bet you are at max for the head unit.
Old Mar 30, 2010 | 02:30 PM
  #24
MikeGyver's Avatar
Default Progress Report
Originally Posted by SincalT/A
Im gonna save you some time "Build a new inlet use the original blower flange only". ...
OK.
Old Mar 30, 2010 | 02:39 PM
  #25
MikeGyver's Avatar
I left out that in the 1st pic you can see how the flange blocked off part of the blower inlet, and in the 3rd pic I cut it out to match.
Old Mar 30, 2010 | 02:48 PM
  #26
Spoolin's Avatar
GFYS and STFU
You've got the right idea but I'd get those beads pressure tested.
Old Mar 30, 2010 | 05:11 PM
  #27
MikeGyver's Avatar
That's the most polite way that I've ever heard of saying that my welding sucks. I know, but I'm cheap. It's welded inside and out. A little leakage instead of drilling the throttle plate? Don't worry, it will be invisible after a little flat-black paint.
Old Mar 30, 2010 | 05:42 PM
  #28
A Low Dime's Avatar
13 Second Truck Club
Looks like it should be a nice improvement, the 102mm is much larger.
Old Mar 31, 2010 | 09:19 PM
  #29
MikeGyver's Avatar
I took a pic to show that the working side looks a lot better than the outside:
And I made a video to show how it sounds now:
http://www.youtube.com/watch?v=SGdFb7g7ZUQ
Old Mar 31, 2010 | 10:09 PM
  #30
Spoolin's Avatar
GFYS and STFU
That video was awesome!!
Welding has improved Daniel-san!
