ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old Jan 6, 2020 | 02:47 PM
  #551
ILuvJDM's Avatar
It's a 4L80e with a VAS fab crossmember.
Old Jan 6, 2020 | 02:52 PM
  #552
ILuvJDM's Avatar
Originally Posted by Jeebalow
So you went from 4.6° at rear to 7.6°. The ideal working angle is 0.5 to 3°. Check out this spicer manual on drivelines.
Edit- Can you put a spacer under your transmission? That's what I did to mine to get it under 3. Maybe space it to get to match the rear without the shim?
Do you know what the factory transmission angle should be? How much did you shim your trans in inches?
Old Jan 6, 2020 | 02:57 PM
  #553
stroker87's Avatar
ok i just looked true your pics and see what your saying, your drive shaft angles up as it exits out of the trans so you need to be like that last pic but the diff on left side and trans on the right
it kinda looks like you need to lower your trans to help you get the angles right
Old Jan 6, 2020 | 03:01 PM
  #554
ILuvJDM's Avatar
I really don't feel like we are on the same page here man, lowering the tranny would make the angles even worse. Raising the tailshaft is the only thing that will lessen the operating angles of the u joints.
Those numbers in my drawing today were just hypothetical numbers. Right now my tranny is 6.1 degrees and the rear end is 2.7 degrees without any shims. I added a 3 degree shim, so now it's 6.1 degree on trans and 5.7 degree on diff, which makes them very close to parallel, but the vibration is still very violent.
Old Jan 6, 2020 | 03:53 PM
  #555
stroker87's Avatar
them being that close and it being violent either your off on your numbers or you are making contact with something
Old Jan 6, 2020 | 04:05 PM
  #556
ILuvJDM's Avatar
I believe it's because the u joints are operating at around 7.5 degrees when they apparently should be 1-3 degrees. Definitely not contacting anything or I would surely see damage on the driveshaft.
Old Jan 7, 2020 | 01:02 PM
  #557
stroker87's Avatar
so i been thinking about this...
i do think you should raise your trans up at the rear if it needs a few inches or more (if you can ) some square tubing would work, the reason i say that is my truck right now lowered same as yours but i did a shock relocation kit so right now under hard acceleration and @WOT shifts im getting a vibration due to axle wrap not sure if its the u joint or the driveshaft is making contact with something under the truck (think its the driveshaft have not had time to check) but with that said if you angle the nose of your diff up your going to make the drive shaft closer to the cab and cross supports and that might be a problem if you load, tow or even hitting bumps so if your able to raise the rear of the trans and get the drive shaft nose down at the axle side get the angles right that would be your best bet
Old May 25, 2022 | 12:39 PM
  #558
Steven Taylor's Avatar
Registered User
Default Fuel pump setup
I'm putting a 04 silverado 1500 rcsb together and it has a returnless fuel system. how did you setup your system? So far I plan on using the DW400 fuel pump module .
Old May 30, 2022 | 08:45 PM
  #559
Stubbyfoil's Avatar
Registered User
This build is fire! Reminds me of my turbo 6.0 but 100x cleaner! Lol
vicalma03
Jun 13, 2012 08:25 AM
GoFast908Z
Feb 21, 2011 10:04 AM
Matt@adams
Sep 9, 2010 12:28 AM
colekill
Sep 1, 2009 09:32 PM
fbs2s
Oct 5, 2008 10:06 AM
