I hope I'm not late for work!
Old Jan 4, 2014 | 03:51 PM
  #231
Atomic's Avatar
I have a gauge for that
New radiator came in today...brand new from summit for $130 shipped, even has the oil cooler ports!
Started it up and everything seems fine except it looks like both of my narrowband o2 sensors are trashed, which isnt really surprising given what they saw
Old Jan 4, 2014 | 04:57 PM
  #232
BlackGMC's Avatar
Resident Retard
Well i guess that is good and bad. At least your heading in the right direction.
When the motor was apart did you change up anything besides those studs?
Old Jan 4, 2014 | 05:12 PM
  #233
Atomic's Avatar
Im just glad the bottom end isnt hammering away and the oil pressure is good.
Nope only thing I changed was had the heads surfaced and new gaskets and studs. Figured it was working fine before and no need to change anything!
New rad, as if yall dont know what one looks like!
I did get my EGT gauge installed...at idle it looked around 700...what does yours say?
Old Jan 4, 2014 | 05:19 PM
  #234
BlackGMC's Avatar
Resident Retard
mine idles around 700-800 once fully warmed up. Cruising with the 4.10s it would be around 950 at 60 and 1050 at 70... With the new 3.42s it does around 900 at 60.
When i first started tuning with it at 60 is was around 1200* timing in the low 30s, now the timing is in the low 40s and the temps are what i mentioned earlier.
However my probe is post turbo next to the wideband. About 1 foot from the turbo housing.
Old Jan 4, 2014 | 08:24 PM
  #235
Spoolin's Avatar
GFYS and STFU
Are the EGT's on a Diesel a lot less than on that of a gasser?
Old Jan 4, 2014 | 08:27 PM
  #236
TIM Z's Avatar
11 sec. Truck Mod
At idle or WOT ?
Old Jan 4, 2014 | 09:01 PM
  #237
Spoolin's Avatar
GFYS and STFU
Originally Posted by TIM Z
At idle or WOT ?
I guess both. Just seems high to me after watching my Diesel EGT's. At idle I see maybe 250-300* and at WOT, if I stay in it for 12-14 seconds it might crack 1000*, and that's with a hot tune @ 24psi. Never had an EGT on my gasser so I don't have a feel for what those would be.
Old Jan 4, 2014 | 09:45 PM
  #238
Atomic's Avatar
A lot lower on diesels. Diesels run lots of excess air except at high power which is part of the reason they smoke so much at high power.
Old Jan 4, 2014 | 11:40 PM
  #239
Spoolin's Avatar
GFYS and STFU
Yeah that's why it's suprising, excess air = leaner = runs hotter.
I know when the Diesel guys EGT's get too hot (1800-2000) they dump extra fuel to cool down the exhaust, but I guess I never thought that gassers would run hotter under regular driving conditions.
Figured the gassers would run cooler since they are closer to stoich for the most part than Diesels. Diesels are more forgiving with their AFR which is why assumed the opposite. I gotta re-think my thinking cuz obviously I'm wrong! Lol
Old Jan 4, 2014 | 11:44 PM
  #240
1FastBrick's Avatar
Custm2500's Rude Friend
As usual!!! That also shines some light on your homo sexual tendancies.
