I hope I'm not late for work!
Old Jul 7, 2013 | 11:03 PM
  #121
JR 427's Avatar
What tires are you running? Man, your vids never get old!!
Old Jul 8, 2013 | 09:25 AM
  #122
Atomic's Avatar
I have a gauge for that
m&h drag radials 275/50/17
May be hitting the dyno tomorrow...tested out the new converter, slip is still a little higher than I would like but its much better, 14% compared to 30% before. Makes a huge difference!
Old Jul 8, 2013 | 10:35 AM
  #123
BlackGMC's Avatar
Resident Retard
does the slip amount vary depending on the gear? Meaning 1st is different and 2nd then 3rd... I am just curious.
Old Jul 8, 2013 | 10:54 AM
  #124
Atomic's Avatar
Yes, generally the higher the gear the more load you put on the converter. For instance before I had mine restalled at 6200 engine rpm the converter slip amount was 1100 in 1st gear, 1300rpm in 2nd gear, and 1500rpm in 3rd gear.
I also tightened my plugs down to 0.020 and gained a couple psi of boost, which tells me it was blowing the spark out before.
Old Jul 8, 2013 | 12:10 PM
  #125
WhiteX's Avatar
Just out of curiosity what plugs are you running? And have you ever tried a smaller tipped electrode/race cut plug?
Old Jul 8, 2013 | 02:09 PM
  #126
Atomic's Avatar
Right now they are br7ef @0.020. I have used b8efs in the past but they did not idle well at all. Ive only tried the tr6s, br7ef, and b8efs. Which plugs are you reffering to?
Old Jul 9, 2013 | 11:52 AM
  #127
WhiteX's Avatar
Something like an iridium tipped plug like an Autolite XP103 or an Autolite Racing AR103.
Both, especially the iridium, would offer a stronger spark concentration to thwart off spark blowout.
Old Jul 9, 2013 | 04:22 PM
  #128
chevyboy.520's Avatar
How does the truck run with the gap set to .020?
Does idle any different?
You picked up some boost so does it feel like it picked up some power to?
Old Jul 9, 2013 | 05:00 PM
  #129
oakley6575's Avatar
Damn that is a tight gap. Does it blow the spark out when running it at .030?
Old Jul 9, 2013 | 06:00 PM
  #130
Atomic's Avatar
Yea it seems to mis a lot with a 0.030 gap, and seems to mis above 20psi with a 0.025 gap. No more missing with a 0.020. It idles fine.
