I hope I'm not late for work!
Old Jan 23, 2016 | 05:11 PM
  #1251
Atomic's Avatar
I have a gauge for that
I know I can beat everyone off the line with a bed full of firewood without going into boost, so I am pretty satisfied thus far. Its interesting driving with the blower vs the turbo...with the turbo, it was basically give it some throttle and the turbo would keep spooling even with a constant throttle...so after a time the power would increase without you giving it more throttle. With the blower, you have to WANT it to make boost, which takes more encouragement from the loud pedal.
Old Jan 23, 2016 | 07:09 PM
  #1252
lxcoupe's Avatar
The cam sounds great! I love the clean, smooth lope that seem to be characteristic of 115+ LSA cams, imo that's how all cams should sound.
Old Jan 23, 2016 | 07:23 PM
  #1253
FFDP's Avatar
You know, technically it's illegal to pump gas with the vehicle running.
I've never understood why people do it, the vehicle isn't going to get hot or cold in the couple minutes it takes to fuel up.
Old Jan 23, 2016 | 08:00 PM
  #1254
Choda's Avatar
Idle is cool and all but where is the WOT video?
Old Jan 23, 2016 | 09:01 PM
  #1255
Atomic's Avatar
True....but it was cold outside and the wife gets irritated when she is cold, and I wanted to take the opportunity to take this vid
Still haven't gone WOT with the new cam...roads were icy...maybe sometime this week
Old Jan 23, 2016 | 10:54 PM
  #1256
03sierraslt's Avatar
Check your back pressure with the larger cam. Your exhaust isn't hurting you but the primaries most likely are. Don't run dual 2.5" it's way too restrictive, just change up your muffler setup. Mine is very tolerable with dual 3" into single 4".
Old Jan 24, 2016 | 12:28 PM
  #1257
kbracing96's Avatar
Might be able to mess with the bypass valve with a restrictor or an air bleed and get it to close easier to make boost easier if you wanted too.
Old Jan 24, 2016 | 01:01 PM
  #1258
AkSSS's Avatar
Have you ever fueled up a vehicle at -45 degrees? You sit in your warm car.
Old Jan 24, 2016 | 01:48 PM
  #1259
Atomic's Avatar
Pat, what mufflers do you have? The annoying rasp mine has around 2300rpm is really the most annoying. I dont have a ton of room under there for mufflers.
Kyle, it can make the boost with more pedal, I was just commenting on the feel between the two.
Old Jan 24, 2016 | 02:17 PM
  #1260
BlackGMC's Avatar
Resident Retard
That cam sounds really good!
