Holley Dominator Install
Old Sep 13, 2017 | 08:09 PM
  #91
DrX's Avatar
DrX
ABS: The ABS is not operational due to not seeing the 128K pulse/mile VSS signal or data communication from the PCM. But I wanted to test whether the automated bleed can still be performed as the module is still plumbed in. I can confirm that the automated bleed via the ODB connector still works IF you supply 12V on the VSS signal line to the module so that it does not see an open circuit and set a DTC. All DTCs had to be cleared before I could proceed with the bleed. On my truck this circuit is accessible at inline harness connector C152 which is located under the underhood fuse block. Yellow/black wire.
Old Sep 14, 2017 | 12:02 AM
  #92
BlackGMC's Avatar
Resident Retard
So what were the final numbers? Hard to read those printouts
Old Sep 14, 2017 | 07:59 AM
  #93
DrX's Avatar
DrX
Originally Posted by blackgmc
so what were the final numbers? Hard to read those printouts
884 rwhp/863 rwtq @ 17 psi and 20* advance(1120/1090 crank)
Fist pull was with only 9* advance and did about 300RWHP less.
Old Sep 14, 2017 | 05:04 PM
  #94
Vortec350ss's Avatar
It does idle smooth, that is surprising.
Old Oct 5, 2017 | 08:30 AM
  #95
DrX's Avatar
DrX
One thing the Dominator doesn't have is misfire detection. Had an issue that was causing target AFR on the right bank and 6.X on the left when in boost only. Actual was likely 6.X on both.
Old Oct 5, 2017 | 04:58 PM
  #96
MikeGyver's Avatar
Originally Posted by DrX
First time ever on a dyno.....
I swear I saw those nostrils on the hood open wider when he nailed it.
Old May 19, 2018 | 06:44 PM
  #97
DrX's Avatar
DrX
Finally getting around to mounting the Merc Marine/Holley/IGN-1A coils along with the big wire kit for them. Also found 1 more wire with a singed spot on the insulation. Funny how it runs good until the cylinder pressures get high and the path of least resistance for the spark is no longer the plug gap.
Hopefully, this cures the misfires. Also read that the Dominator and GM coils don't get along.
Similar mounting to how I had the GM coils. Drivers side I just spun a couple of nuts onto the longer motor mount bolts that I had used. Pass side I bolted to the frame under the motor mount. Drivers side is shown flipped down and flipped up. Had to change terminals/boots for the Holley coils.
Attached Thumbnails Holley Dominator Install-20180512_154647_resized.jpg   Holley Dominator Install-20180512_154827_resized.jpg   Holley Dominator Install-20180519_172100_resized.jpg   Holley Dominator Install-20180519_172137_resized.jpg   Holley Dominator Install-20180519_172245_resized.jpg
4Runoma
Apr 11, 2016 06:44 PM
GM1697
Apr 8, 2016 05:43 PM
Rocked_Ram
Apr 5, 2016 06:36 PM
Tyjbrown94
Mar 27, 2016 04:58 PM
HDhotrod
18
Mar 18, 2016 10:49 PM
