Funkster's Build Thread
Old Mar 4, 2013 | 06:28 AM
  #21
Funkster's Avatar
12 Second Club
Well guys, how was that for a complete lack of updates? I have been throwing some money at our Subaru lately and am going to try to balance both projects a bit better from this point.
Not much has happened with the truck to be honest. I received a Magnaflow 3" bullet from a member on here and had it installed. Pretty happy with how that came out. I also picked up an e-fan harness and a set of F-Body fans to put on. Truck is already unlocked on HP Tuners, but need to find time for my friend and I to tinker with it. Will probably go ahead and throw a bit of a tune on it as well.
I did also pick up a new set of tires for the stock wheels, but they are just Radial Rover All Season tires, nothing special. Picked up the Tahoe wheels as well, they are just setting in the garage until I can do something with them.
Old Mar 4, 2013 | 07:33 AM
  #22
RibeiroBJJ's Avatar
Praise The Lowered
Cool project, I always liked white silverados...Can you do a small write-up on how you repaired the chips?
Old Mar 4, 2013 | 08:46 AM
  #23
Funkster's Avatar
12 Second Club
There are a few on the Dr. Colorchip system out there if you are looking for somethign right away. However, I will probably be fixing a few more when it warms up in a few weeks. I can do one then.
Old Mar 4, 2013 | 03:57 PM
  #24
Tuckin15s's Avatar
Awesome build can't wait for you to dig into the motor.
Old Mar 5, 2013 | 08:47 AM
  #25
Funkster's Avatar
12 Second Club
Thanks for the kind words.
Hopefully I can start to give you guys more interesting posts to view.
Old Mar 9, 2013 | 06:12 PM
  #26
Funkster's Avatar
12 Second Club
Nothing too exciting, but I did pick up another piece of the puzzle last night.
I also dropped the hitch off the back of it. Probably shaved a good chunk of weight. (although from the worst place) I will likely refinish it in case I need it in the future.
Old Mar 10, 2013 | 11:16 PM
  #27
Funkster's Avatar
12 Second Club
Got my e-fans installed tonight along with help from a couple of friends. Didn't get a chance to really test them out as it is snowing pretty good here.
Also, won't need it for a while but picked this up off of a friend tonight.
Old Mar 19, 2013 | 10:21 PM
  #28
Funkster's Avatar
12 Second Club
This last weekend got a bit more done. Put a tune on the truck that firmed up the shifts and bumped timing a bit. Get a little 1-2 chirp now.
Changed the work lights over to LED bulbs as well. A little brighter and a lot easier on the eyes.
Stock:
Stock on the left, LED on the right:
Both LEDs installed:
Also did a bit of engine bay work. Plan to cut the air box for a bit more airflow and figured I would do some sprucing up and additional work in the process.
I took of the stock airbox mounting plate and cleaned it up first.
Then I laid out a grid and using a punch and a small bit got some pilot holes started.
Then I stepped up the bits until I had 3/4" holes.
I then put the modified plate and plate mount into my stripper tank, did an outgas cycle, blasted the box plate and hit the mount with a Roloc since it had some rust on it.
Coated both pieces and all the mounting bolts in flat black. I apologize for the terrible photo.
I need to get the air box cut as well, but ran out of time. That will be a project for tomorrow.
Old Mar 24, 2013 | 12:04 PM
  #29
Funkster's Avatar
12 Second Club
Finished the air box bottom the other day. Decided to drill holes instead of cutting it up, came out looking good and I think will do the job just fine.
Also got the 4L80E up on the stand and dropped the pan.
Can't say it or the magnet were pretty, but I pans that have had a lot more in them have held up to more power than I will make for a while. Gotta save for a couple weeks now and then will be picking up my torque converter. In the mean time I am going to do some more small maintanence things and maybe a bit of interior work.
Old Mar 28, 2013 | 10:43 PM
  #30
Funkster's Avatar
12 Second Club
Last weekend I swapped out my stock end link and swaybar bushings for Energy Suspension pieces. The install was pretty easy as I was lucky my bolts weren't all rusted to hell. The result seems to be less body roll and more corner stability. The downside is, it didn't fix the clunk I am having in the front. So that is still on the list to find and fix.
After that I went to swap the license plate lights to LEDs and relaized they weren't working. I changed the bulbs assuming they were both burned out, and they still didn't work. Everything was plugged in as it should be, so I pulled the license plate harness.
I took the harness apart and found a smashed connector pin and a cut up and smash wire. I replaced the wire and soldered on new pins. I cleaned up all the loom with some degreaser, heat shrinked the look and wrapped the still visible parts in electrical tape.
Powered it up with my makeshift 12v testing station and tested it out. Both lights lit up as they should.
Also picked these up.
I have a spare crossmember on the way and it should be here tomorrow. I am going to get it cut and welded for the 4L80E this weekend as well as pick up some manifold flanges for the turbo kit.
