Dirty Dan's RCSB 4X4
Old Apr 1, 2020 | 02:20 AM
  #251
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by _zebra
pray tell... because i've got a 450 in the car that took a lot of work to square away (custom bucket & bracket + return line conversion because the regulator was overwhelmed). i'd hate to have that go out on a hard run, as i'm already maxing out a stock LS1.
Not sure if they changed the way they manufacture them Or what.
I have heard of Lots of 250's in the 1-2 year range bite the bullet in the last few years. Only a a Few people with 450's that I know that had issues. But I don't know that many people with the 450's
I don't know if it has to do with the Fuel blend or Manufacturing and materials
Old Apr 1, 2020 | 07:43 AM
  #252
03sierraslt's Avatar
I’ve had 450’s for years. (Knock on wood) and currently have the high pressure 450’s (274 I think)
every pump has issues at some point, meaning I can find stories about all of them.
Old Apr 1, 2020 | 09:02 AM
  #253
dantheman1540's Avatar
I wouldn't be upset if I had to change a pump every 3-5 years. just part of the hobby I suppose. 2 years is a little to frequent and its a PITA to pull the bed but I shouldn't have to do that any more now that I chopped a huge hole.
Old Apr 1, 2020 | 08:51 PM
  #254
_zebra's Avatar
makes children cry
shoot... my OEM pump went 210k mi in 16yrs before it rolled over.
Old Apr 1, 2020 | 11:27 PM
  #255
Wish I woulda have kept my OEM one for other random projects. Dont remember why I trashed it. New pump will be here either tomorrow or Friday.
Old Apr 2, 2020 | 08:08 PM
  #256
Bench tested the assumed bad 450 and with power coming directly from the battery it kicks on. However it's not very loud and sounds lower pitched and weak compared to the new one tested the same way.
I was sorta expecting the old one to not kick on at all since I saw no FP at the regulator but I suppose it could be so weak that it can't generate any pressure 🤷‍♂️
Old Apr 3, 2020 | 10:19 PM
  #257
Swapped in the new Walbro and she fired right up. Did about 8 full 2-3-4 passes at my local Mexico to get some data. Heres some junk to look at while your quarantined. Sorry about the terrible audio quality. I need to invest in a quality camera.
Old Apr 4, 2020 | 01:55 AM
  #258
_zebra's Avatar
makes children cry
"my local Mexico"
classic
Old Apr 10, 2020 | 09:08 PM
  #259
Well been seeing smoke under throttle again. At first I thought It was just burning all the oil that was likely trapped in my huge muffler. But it's been 300 miles and it's still the same. Doesnt smoke on start up that I can tell, doesn't smoke at idle but under load or throttle it smokes and gets worse the heavy my foot gets. It's not horrible like a james bond smoke screen or when the head gasket was bad. But it's enough I'm concerned. Still runs and drives fine and has taken a load of abuse.
Ordered a leak down test kit and plan to do that next week.
Here's another little run in another country.
Old Apr 10, 2020 | 09:51 PM
  #260
Also from today. Didn't smoke much in video but when I stopped down the street and then got back on it theres was a good bit of smoke.
