Dark Star - 2014 Silverado RCSB
Old May 24, 2014 | 11:52 AM
  #91
sTNT971's Avatar
cool man
u gr8 work on ur truck
ur lowering kit brand its very good also its smooth
Old May 24, 2014 | 04:24 PM
  #92
bigsapper's Avatar
1st Place
Thanks for the support!
Old Jun 6, 2014 | 10:42 PM
  #93
Yolo92's Avatar
Default 3/6 drop
Does your truck sit level??Just got a djm kit installed a 3/6 djm kit and the rear sits a higher,,
Old Jun 7, 2014 | 10:00 AM
  #94
Choda's Avatar
Tell the girls to move outta the way. Lol
Great truck
Old Jun 7, 2014 | 10:18 AM
  #95
MikeD.'s Avatar
How low can you go on these nnnnnnnbs's before you have to notch?
Old Jun 17, 2014 | 09:50 PM
  #96
bigsapper's Avatar
I would guess its about the same as the NNBS. 4/7 doesn't seem to be a problem.
Old Jun 17, 2014 | 09:53 PM
  #97
bigsapper's Avatar
I have the belltech kit set for 3/6 and it's about 1/2 higher in the rear.
  #98
bigsapper's Avatar
Great truck
Thanks.
Old Jun 17, 2014 | 10:04 PM
  #99
bigsapper's Avatar
OK, so Airaid has hesitated in developing/releasing an MIT kit for the 2014. I'm completely sold on the MIT based on the results from the research that Black Bear Performance did.
So this is what I did with input from others that did the real trial and fitting...
Airaid PN 200-996 is a direct fit for the 2014 5.3L. Amazon.com: Airaid 200-996 M.I.T. Modular Intake Tube: Automotive
However, you need to customize for the PCV system.
Buy a 23/32 drill bit...23/32" High Speed Steel 1/2" Shank Drill Bit (S + D type drill) - Jobber Drill Bits - Amazon.com
Drill out the included vent hole and another on the driver's side bend.
Tap it with 1/2"-14 NPT http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Use these fittings ... Thogus Polyethylene Tube Fitting, Adapter, Black, 1/2" NPT Male x 5/8" Barbed (Pack of 10): Barbed Straight Fittings: Amazon.com: Industrial & Scientific
And connect with this hose (cut to length) Amazon.com: Goodyear 65071 Heater Hose: Automotive
I used this spermatex to seal the fittings to the tube... Amazon.com: Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker, 3.35 oz. Tube: Automotive
Make sure your trim & file your edges after you drill and tap the holes. Clean the tube out so you don't get crap sucked in the intake.
Here's pics...
Old Jun 22, 2014 | 12:35 AM
  #100
bigsapper's Avatar
I suck.
Went to the strip tonight. I made 5 passes and the first was my best...14.757 @ 99.38mph.
Second pass was the worst...16.801 @ 97.31mph.
No traction with these crappy Yokohama tires.
I need Caltracs and better tires.
