C3 build
#931
well some good news is I now have decent battery voltage. around 13.5. still having some fuel pressure issues. mainly in 2nd gear. My 1-2 shift is at 6300 and is fine but my 2-3 shift is at 5800 to keep enough fuel pressure and I haven't gone past 5800 in 3ed. I may order a new Bosch 044 or one of the 044 knockoff and see if it helps with that. I added about 5% to the trans 2-3 shift pressure table. it shifted but its really sluggish. added 2% more and is better. added another 2% but didn't get a chance to test it. I also added 20% TM into the tune for the 2-3 shift to help it out. Hopefully the new pump will get here before next Friday so I can install it and test it out at the track.
#933
well Im hoping it works. Also, on my 2-3 shift, looking at my log, the rpms are rising in a linear fashion, at my set shift point the rpms jump from 5900-6300 then it shifts. I have my shift times zeroed out. now running 10% over stock trans pressure on the 2-3 and have 20% TM for the 2-3 shift.
#937
Checked my trans fluid this morning. Looks a little high. Checked it after I got home from work, engine still running. but still red. It does have a slight burnt smell. Running the Supertech walmart fluid. Think it would help if I put something better in there? has about 15K miles on it.
