C3 build
Old Sep 27, 2012 | 08:00 PM
  #831
AndysC3's Avatar
Is there an easier way to get to the fuel pump power wire than from the bottom of the fuse box? Going to use a relay and that wire is going to be my trigger source.
Old Sep 27, 2012 | 08:09 PM
  #832
smokeshow's Avatar
Mod with training wheels
Its not very hard to get to.
Old Sep 27, 2012 | 08:14 PM
  #833
AndysC3's Avatar
you offering some help lol
Old Sep 27, 2012 | 08:30 PM
  #834
smokeshow's Avatar
I could probably point it out lol.
Old Sep 27, 2012 | 08:31 PM
  #835
AndysC3's Avatar
thanks lol
Old Sep 27, 2012 | 09:01 PM
  #836
darnie's Avatar
dont forget to install the easy button.... PS may come see whats up n a few weeks
Old Sep 28, 2012 | 05:01 PM
  #837
AndysC3's Avatar
Started the fuel pump wiring today. got the relay wired up. Just need to run the wire from the relay to the pump. But when I went to start the truck it had a very rough idle. Getting code P0200. Got out my water spray bottle and sprayed the exhaust primaries. Bank 2 is not firing at all. I have the Big 3 wiring upgrade, and when I removed the cover for the fuse box the wire from the alt to battery touched the neg terminal and sparked. Everything seemed fine. Could it be related to my no fire on bank 2? what should I check?
Old Sep 28, 2012 | 05:06 PM
  #838
darnie's Avatar
P0200 Injector Circuit Malfunction
try what it talks about at the end check your voltages
Old Sep 28, 2012 | 05:14 PM
  #839
smokeshow's Avatar
Check the fuse for injectors/coils on bank 2.
Old Sep 28, 2012 | 05:27 PM
  #840
AndysC3's Avatar
Injb fuse was blown.
