C3 build
Old Jul 25, 2012 | 07:52 PM
  #591
03sierraslt's Avatar
So far so good, get some longer bolts and fire that thing up.
Old Jul 25, 2012 | 08:01 PM
  #592
AndysC3's Avatar
Im working on it lol. Waiting on one of my buddies to give me a ride to the store. In the mean time I've been working on the tune a bit. Set the 1-2 shift to 5800 rpm to start. and the 2-3 to 6000. double checked the timing tables and ve table. Everything looks good to do some logs tonight lol
Old Jul 25, 2012 | 08:28 PM
  #593
Start out on the rich side and conservative on timing, then just work it in line. What kinda boost you figure you are at now?
Old Jul 25, 2012 | 09:18 PM
  #594
AndysC3's Avatar
Yea, afr was about 10.5 on the first pull. Aiming for 11.3-11.5 for now. Timing was 4.5-5. Should be about 8-9 psi at 6k.
Old Jul 25, 2012 | 09:24 PM
  #595
What's your CR with those heads?
For referance I am running 12psi w/ 18 degree total timing on Meth though.
Old Jul 25, 2012 | 09:27 PM
  #596
AndysC3's Avatar
Still 9.5. Well see how it likes timing as I go.
Old Jul 25, 2012 | 10:50 PM
  #597
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Be careful running timing that low, you're going to have REALLY hot exhaust. Some people have fought detonation due to the exhaust valve getting so hot.
Old Jul 25, 2012 | 11:34 PM
  #598
AndysC3's Avatar
its just where I'm starting. Haven't been able to do many logs with boost. But for some other news. The fast 65# injectors are in and I started the truck. Idles just like before and no signs of leaks. Idle afr is the same as before and fuel pressure is at 50 psi at idle.
But some more bad news, One of the coolant hoses that goes from the water pump to the firewall broke. I wasn't even prying on it. I was connecting the #8 injector in and it just fell. And there's no way to reattach it. so for the time being I cut the other hose and connected them together. I need to get some hose clamps as there is a slight leak when the truck is on. Seems as soon as I get good news something else happens.
Old Jul 25, 2012 | 11:57 PM
  #599
milkey57's Avatar
Glad to see you got the injector issue fixed! Now get on that bitch
Old Jul 25, 2012 | 11:59 PM
  #600
AndysC3's Avatar
haha, I dont want to drive it with the coolant hose dripping. I take the girlfriends truck to the walmart later and pick up some worm gear clamps to help stop the leak. Ive only had about 3 hours of sleep in the past 36.
