C3 build
Old Jul 26, 2012 | 12:20 AM
  #601
pewterliftedz's Avatar
I broke the nipple off of the heater core when I did a cam swap on my old truck. I cut it off with a dremel and got a new 1 from the dealer.
Old Jul 26, 2012 | 12:25 AM
  #602
AndysC3's Avatar
yea, I may have to do something like that. I try and get a pic and post it up to see if we are talking about the same thing. These coolant lines are starting to become a PITA. Guess thats what happens with a 12 year old truck thats spent its whole life in the AZ heat.
Old Jul 26, 2012 | 12:48 AM
  #603
AndysC3's Avatar
and even with the spacers the fuel rail didnt line up quite right. I had to drill a hole in the mount on the fuel rail to mount it. Im definitely taking the manifold off next time I mess with the fuel system.
Old Jul 26, 2012 | 01:52 AM
  #604
Spoolin's Avatar
GFYS and STFU
Just loop the coolant hoses and bypass the Heater core for the time being since you cut the hoses already.
Since I deleted A/C and such on my truck I just looped those hose lines around.
Old Jul 26, 2012 | 02:05 AM
  #605
AndysC3's Avatar
yea, I already have them looped together. Just need some hose clamps to keep it from leaking.
Old Jul 26, 2012 | 02:31 AM
  #606
Spoolin's Avatar
GFYS and STFU
then stick your finger in the hole and STFU...I'm trying to ***** the forum here!!
Old Jul 26, 2012 | 03:05 AM
  #607
AndysC3's Avatar
lol. already have some brass in the hole. But its still leaking.
Old Jul 27, 2012 | 07:32 AM
  #608
AndysC3's Avatar
So more issues with the fuel system. Key on engine off I'm getting 50psi and wot is 50psi. So the injectors are maxed at 5500 rpm. Guess I need a new fpr
Old Jul 27, 2012 | 08:29 AM
  #609
AndysC3's Avatar
Also, its not shifting at the commanded shift points. Had the 1-2 shift commanded at 5400 and 33 MPH and it went all the way to 5700 then went into REP mode.
Old Jul 27, 2012 | 10:10 PM
  #610
AndysC3's Avatar
It shifts great with anything under wot. Afr is at 11.3-11.5. Max timing was 9.5. And about 140kpa or 6psi at 5400 rpm
