C3 build
#592
Im working on it lol. Waiting on one of my buddies to give me a ride to the store. In the mean time I've been working on the tune a bit. Set the 1-2 shift to 5800 rpm to start. and the 2-3 to 6000. double checked the timing tables and ve table. Everything looks good to do some logs tonight lol
#598
its just where I'm starting. Haven't been able to do many logs with boost. But for some other news. The fast 65# injectors are in and I started the truck. Idles just like before and no signs of leaks. Idle afr is the same as before and fuel pressure is at 50 psi at idle.
But some more bad news, One of the coolant hoses that goes from the water pump to the firewall broke. I wasn't even prying on it. I was connecting the #8 injector in and it just fell. And there's no way to reattach it. so for the time being I cut the other hose and connected them together. I need to get some hose clamps as there is a slight leak when the truck is on. Seems as soon as I get good news something else happens.
#600
haha, I dont want to drive it with the coolant hose dripping. I take the girlfriends truck to the walmart later and pick up some worm gear clamps to help stop the leak. Ive only had about 3 hours of sleep in the past 36.
