C3 build
Old Feb 2, 2013 | 01:57 PM
  #1071
ak2007r6's Avatar
Nice!
Fall asleep at the light?? LOL
I bet you have a 1.7 60' in her
Old Feb 2, 2013 | 02:05 PM
  #1072
AndysC3's Avatar
I was against my buddy. Was going to give him 3 sec and do a fly by by him but he took too long. Lol
Old Feb 2, 2013 | 03:44 PM
  #1073
AndysC3's Avatar
My converter is holding me back a lot. If I hold the brake and hold the gas at 100% it will go to 3200 with 2psi. On my logs you can see where the cam picks up at 3600 rpm. Need the converter restalled to that. And I need a better intercooler and a bigger meth injector. I'm sure I could see low 12s maybe even 11s once that's done
Old Feb 2, 2013 | 03:47 PM
  #1074
ak2007r6's Avatar
I was having pretty good results with mine just revving it to the mid to high 1000's RPM and then stomping on it when green. Would flash the converter and launch pretty hard.
Haven't tried stalling it up or building boost yet but might be worth doing a few logs trying different ways and see what works best.
Old Feb 2, 2013 | 03:48 PM
  #1075
ak2007r6's Avatar
And I agree. I would guess you should be in the mid to lower 12's with your setup pretty easy
Old Feb 2, 2013 | 04:10 PM
  #1076
AndysC3's Avatar
Yea. My first race I left off idle because the starter had me roll down my window to tell me something and started the tree as I was rolling my window up. Did a 2.2 60' and a 13.2@102 in the 1/4. Mine reacts best with the throttle at 100%. I'm going to look into having Chris restall my converter to about 3600. And do a 4psi launch
Old Feb 2, 2013 | 05:51 PM
  #1077
smokeshow's Avatar
Mod with training wheels
Sounds like dumb **** that SIR would do. They really need to pick up their game if they are about to be the only track in AZ...
Anyway, I'd have a look at what your tune is doing when you're not full boost... Low boost torque with a procharger is going to have an effect on how high you can brake stall it. Play around with timing and AFR in the area that it stops building boost and see if you can't bump the torque up to push the RPM higher against that converter.
Old Feb 2, 2013 | 06:43 PM
  #1078
sharpshooter's Avatar
I always had my best 60's flashing it off idle. Prochargers don't make boost when stalled up like turbos.
What rpm will your converter flash to off idle?
I think your set up could run high 11's if you change a few things.
Old Feb 2, 2013 | 07:33 PM
  #1079
03sierraslt's Avatar
Good deal man, its getting there. They just take some tweaking.
Old Feb 2, 2013 | 07:47 PM
  #1080
AndysC3's Avatar
My first run off idle was horrible. My best 60' came from stalling it up to 3200. Made 2 psi that way. It flashs to about 3100
