Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
#2112
#2113
Yeah I still have it.
I know. Supposed to take the motor to the dyno at some point. I'm sure that'll get me fired up pretty good. Especially since it'll have the blower on it.
#2114
If you're asking cause you want to buy it, I need to check with a buddy of mine Casey. He told me he was gonna buy it. I told him I was in no rush, so when ever was convenient for the both of us we'd do the deal. He's about 4 hrs drive from me.
I'll just let you ******* get in a bidding war and I'll throw in this bad as centri cam I've had on my desk for ever.
#2118
Rossler Terminator 3 TH400
Upgrades from my Receipt:
Ross-Lock Pro Tree Trans Brake Reverse Shift w/2.48 Gear Set
All Gaskets, Seals, Bushings, Bearings, Sealing Rings, Rear Case Thrust Bearing
Glass Beed, Trim Ears, Prep Case for Racing
HP Overhaul New Bushings, Seals, Gaskets, Clutches, High Flow HP Filter
Patented Snap Ring Stabilizer
Special Design M300 Billet Input Shaft with 1.250 Diameter Spline on Drum Side
CNC Modified Forward Drum with Over Sized Spline for Extra Durability with Rossler Exclusive Shaft Retainer System to Prevent Shaft Movement
Billet Forward Clutch Hub
HD 34 Element Sprag
Aircraft Grade Quality 7075-T6 Billet Aluminum High Gear Drum, Eliminates 4.5 lbs of Rotating Weight From Transmission, Also Prevents Drum Explosion for Durability and Safety, with Billet Steel Sleeve to Prevent Premature Sealing Ring Wear In Drum Bore
HD Clutch Packs 6/6/4
Ross/Lock 2nd Gear Snap Ring Stabilizer
+2 Quart Cast Aluminum Pan
Lokar Dipstick (with stub if you don't want a permanent dipstick)
AN6 Cooler Fittings
Total Price New: $2962.00
CSR Super Trans Shield: $444.97
Total Cost New: $3406.97
His prices have gone up slightly since I bought it, so it would probably be a hundred bucks or so more now.
HD 34 Element Sprag
AN6 Cooler Fittings
#2119
A while back, I said I was gonna start a big for sale thread. I've been trying to get it all together and here is what I have so far. I'm make a formal ad with pics and **** when I get everything accounted for.
Jaz Aluminum 10 gallon Fuel Cell ($259.97)
Upgrades: (2) -12 Outlets ($81.94), (1) -10 Return w/Return Tube ($17.94), (1) -12 Rollover Vent ($39.95), Extra Mounting Pads, Total Price New: $399.80
Price + Shipping + Paypal Fees: $280.00
Magnafuel Electric Fuel Pump Part No. 4303 ($485.97)
Upgrades: -12 Inlet Fitting ($15.97), -10 Outlet Fitting ($11.97), Total Price New: $513.91
Price + Shipping + Paypal Fees: $360.00
Magnafuel Fuel Filter Part No. 7009, 74 Micron Stainless (Pre-Pump) ($83.97)
Upgrades: -12 AN fittings ($31.94), Total Price New: $115.91
Price + Shipping + Paypal Fees: $80.00
Magnafuel Fuel Filter Part No. 7008, 25 Micron Stainless (Post-Pump) ($83.97)
Upgrades: -10 AN fittings ($27.94), Total Price New: $111.91
Magnafuel 74 Micron Stainless Filter Element Part No. 7060-74 ($49.97)
Price + Shipping + Paypal Fees: $35.00
Magnafuel 25 Micron Stainless Filter Element Part No. 7060-25 ($49.97)
Entire Fuel System: Fuel Cell, 2 Fuel Pumps, 4 Fuel Filters, 2 Replacement Filters
Total Price New: $1983.20
Price + Shipping + Paypal Fees: $1300.00
Edelbrock Super Victor EFI, Part No.28095 ($434.09)
Upgrades: Port Matched for Fel-Pro Gasket 13123, Large Fuel Rails w/Fittings ($543.88), Wilson Lightweight Billet Aluminum 1" Spacer with 2 4150 Gaskets($95.95), Aaron @ 6061.com Elbow for 4-Bolt Throttle Body ($275.00), Nick Williams 92mm Throttle Body w/racepartsolutions.com 4" Dual Flex Seal Connector ($369.99 and $139.95), Total Price New: $1858.86
Edelbrock Super Victor EFI, Part No.28094 (434.09)
Upgrades: Drilled for Fogger Nitrous Setup, Powder Coated Black, Edelbrock Fuel Rails ($121.71)
Total Price New: $555.80
Price + Shipping + Paypal Fees: $390.00
Powermaster Racing Alternator, Part No. 8062, New Price: $220.00
Price + Shipping + Paypal Fees: $175.00
New Comp Cams Custom Grind, Best use for Centrifugal Superchargers (Procharger), Specs are 3-bolt, 239/251 @ .050”, .624/.632 Lift, 115 LSA, 4 Degree of Advance Ground In.
Price + Shipping + Paypal Fees: $275.00
The Tuning School.com “Tuning the Right Way” Complete Tuning Course
This includes everything that comes with it: Tuning Supplement CD, Quick Start Tuning Guide, 214 Page “Tuning the Right Way” book in color, Tuning Tree and Tuning Process Pages for Bolt-On or Minor Modifications, Heads/Cam/Intake and Forced Induction. This is the Level 1 Tuning Course for HPTuners. Total Price New: $449.00
Price + Shipping + Paypal Fees: $315.00
Rossler Terminator 3 TH400, Upgrades from my Receipt:
Ross-Lock Pro Tree Trans Brake Reverse Shift w/2.48 Gear Set, All Gaskets, Seals, Bushings, Bearings, Sealing Rings, Rear Case Thrust Bearing
Glass Beed, Trim Ears, Prep Case for Racing, HP Overhaul New Bushings, Seals, Gaskets, Clutches, High Flow HP Filter, Patented Snap Ring Stabilizer
Special Design M300 Billet Input Shaft with 1.250 Diameter Spline on Drum Side, CNC Modified Forward Drum with Over Sized Spline for Extra Durability with Rossler Exclusive Shaft Retainer System to Prevent Shaft Movement, Billet Forward Clutch Hub, HD 34 Element Sprag, Aircraft Grade Quality 7075-T6 Billet Aluminum High Gear Drum, Eliminates 4.5 lbs of Rotating Weight From Transmission, Also Prevents Drum Explosion for Durability and Safety, with Billet Steel Sleeve to Prevent Premature Sealing Ring Wear In Drum Bore, HD Clutch Packs 6/6/4, Ross/Lock 2nd Gear Snap Ring Stabilizer, +2 Quart Cast Aluminum Pan
Lokar Dipstick, AN6 Cooler Fittings, Total Price New: $2962.00, CSR Super Trans Shield: $444.97
Price + Shipping + Paypal Fees: $2400.00 (I would prefer not to ship, but will if buy makes all arrangements) I do have a pallet I can put it on.
Tru-Cool 40,000 GVW Transmission Cooler, Part No. 47391 ($138.00)
Upgrades: Converted to -6 AN Lines, 4 90* -6 Hose Ends (79.88), 2 Jiffy-Tite Quick Disconnects (150.00), About 15' of -6 Stainless Braid Line (117.00), Total Price New: $484.88
If you want the Cooler/Dual Pump Cradle Mount, I’ll Throw It In For Free.
Price + Shipping + Paypal Fees: $340.00
Rossler TH400 + Tru-Cool 40,000 Cooler + Transmission Cooler Cradle Mount: Price + Shipping + Paypal Fees: $2500.00
Entire Air 2 Water Intercooler Set Up:
Precision PT2000 A2W Intercooler: Price New $1899.99
4” racepartsolution.com V-bands with O-rings: Price New $113.80
Chisled 6 Gallon Tank with Rule2000 Pump (16”x9”x9”) w/1” NPT Female Fittings: Price New $305.00
(4) -16 AN to 1” NPT Fittings: New Price: $77.98
(4) 90* -16AN Hose Ends: Price New: $167.98
(1) 180* -16 Hose End: Price New: $58.97
(1) Straight -16 Hose End: Price New: 26.97
(1) -16 Bulk Head w/Nut: Price New: $10.94
33’ Earls Pro-Lite 350 -16 Hose: Price New: 467.97
Total Cost New: 3129.63
Price + Shipping + Paypal Fees: $2200.00
#2120
I talked to Casey. He's a little on the fence. I basically took that as "if you find another buyer go ahead and sell it". I've got a small pallet and can box it in with plywood. I would just prefer you organize the carrier. We have tons of them down here in Houston. I don't think shipping would be more than around 200 bux terminal to terminal, but you'd have to check. If you want it, lets do something. I could use the 2500 right now to help get the truck back together. So even though I would prefer to keep it for a future project........I'll let it go.
Let me know.
Let me know.
