BlackGMC build take 2 - Turbo Time
Old May 5, 2014 | 04:56 AM
  #581
TIM Z's Avatar
11 sec. Truck Mod
Mmmmm **** . Looks awesome.
Old May 5, 2014 | 06:49 AM
  #582
Atomic's Avatar
I have a gauge for that
Originally Posted by BlackGMC
I have had that same fear. Luckily if i swap the hoses around it gives me more clearance. Hopefully one of the two options will work. If not i will try something else. The big unknown us id the tranny dipstick will hit anything. Time will tell
Hoses flipped
With them flipped like that I dont think it will clear the back of the firewall...
Old May 5, 2014 | 08:51 AM
  #583
BlackGMC's Avatar
Resident Retard
Time will tell. I still have some other options i can try.
Old May 5, 2014 | 09:57 AM
  #584
TXsilverado's Avatar
looking good. when will you have time to cut some plug wires down like that for me? lol
Old May 5, 2014 | 08:35 PM
  #585
blown02408's Avatar
02 w/ lowest mileage 2800
How is the feed being routed? Why would you run the inlet up on top of the manifold like that instead of pointing it down towards the bellhousing?
Do not run fuel lines over the bellhousing/ flywheel area unless they are run inside of thick steel tubing, if the trans let's go it can get ugly quick.
Also if you run at an NHRA sanctioned track you cannot have a fuel regulator, y-fitting, distribution block within 6"s of the firewall, just an FYI.
Be safe!
Old May 5, 2014 | 09:00 PM
  #586
BlackGMC's Avatar
Resident Retard
Be safe!
Was not aware of the Y fitting rule. I wonder why?
Old May 5, 2014 | 10:35 PM
  #587
oakley6575's Avatar
I wasn't either. Good info.
Old May 6, 2014 | 12:22 PM
  #588
blown02408's Avatar
Not completely sure, but I've been busted on the y-fitting rule before. A tech inspector went out of his way to show me it in his book, must of been a revision since the last time I looked.
Old May 14, 2014 | 08:47 PM
  #589
BlackGMC's Avatar
Resident Retard
Well the Y fittings is still kinda close to the firewall but oh well. This should clear the cowl and firewall. I still need to run the return under the intake but that will be another day.
Old May 14, 2014 | 11:16 PM
  #590
LS1TRUCKGUY's Avatar
are those taylor plug wires the 98005 or 98006?
looks sweet!
