Back in the game. RCSB 1500 D-max swap coming...
Old Aug 2, 2013 | 06:57 PM
  #471
thunder550's Avatar
High on diesel fumes
Yep they are push rod engines. The rods are quite a bit longer than the LS motors.
Here's one side with the rockers removed
Other side with the rockers still on
Bottom of heads
Valvetrain
Injectors
Old Aug 2, 2013 | 07:12 PM
  #472
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Alot of work! Did the injectors on my l 7 and there was a lo to remove to get to them, what your doing is even more! I must have missed the reason your doing this?
Old Aug 2, 2013 | 07:17 PM
  #473
thunder550's Avatar
Head gaskets were bad...they were leaking and pressurizing the cooling system. It spit some coolant out the overflow, and when I opened the cap a shitload of it came gushing out. LLYs are notorious for bad head gaskets.
Old Aug 2, 2013 | 10:40 PM
  #474
silver-mod-o's Avatar
Hunt&Fisherator
I don't miss those days
Old Aug 6, 2013 | 09:24 PM
  #475
thunder550's Avatar
Got one cleaned up! Almost done with the second one too. Downpipe and gauges will be here tomorrow. Gauge pod, new gaskets, LML exhaust manifold, and LBZ mouthpiece will be here Thurs. Going to take the passenger side up pipe and one of the intake pieces in to have bungs welded on them for EGT and boost gauges as soon as I get the gauges in.
Old Aug 7, 2013 | 11:07 AM
  #476
kbracing96's Avatar
And after this, your going to rebuild your own transmission too right?
Old Aug 7, 2013 | 01:27 PM
  #477
thunder550's Avatar
Thinking about it! I kind of like this whole "be patient and take your time" kind of thing, rather than my typical get it done as fast as possible mentality. It seems to work out better
Want to come build a trans with me if/when I get my annual bonus in Feb next year?
BTW, the truck started puking coolant right afer you left last time. I'm sure this is somehow your fault.
Old Aug 8, 2013 | 10:19 AM
  #478
kbracing96's Avatar
BTW, the truck started puking coolant right affer you left last time. I'm sure this is somehow your fault.
It's cuz I pee'ed in your coolant tank!! Haha! Sure, I'll bring my Dmax and IF yours works after you get done, I'll "LET" you do mine!!!!
Old Aug 8, 2013 | 09:18 PM
  #479
thunder550's Avatar
Must be the "good buddy" deal you always talk about
Today was parts day! Got visits from the brown truck and the green/purple truck....my favorite kind of day
I got one head reassembled and bolted back down, downpipe installed, and passenger exhaust parts all buttoned up.
SDP downpipe
LML manifold...where is a good place to drill and tap this for EGT gauge?
LBZ mouthpiece
Autometer GM factory match fuel pressure, boost, and EGT gauges
Old Aug 8, 2013 | 09:29 PM
  #480
BlackGMC's Avatar
Resident Retard
Better pictures of the gauges please. Also a link to where you got them.
Also shouldnt you put the egt probe in the downpipe?
