2015 silverado 6.2L build
Old Aug 8, 2016 | 12:33 PM
Det's Avatar
Det
Default 2015 silverado 6.2L build
start off with the basics. I got the truck new in may of 2015. It's a chevy silverado 1500 with 6.2L engine, 8 speed auto trans, and 4x4. It has the LTZ package, crew cab, and short 5' 8" bed. this is what it looked like the day i picked it up.
The stock tires are complete ****, so that had to change. After only 1,000 miles i got all new toyo open country R/T's. mix thread design between all terrains and mud terrains. they grip much better in the wet/snow/dirt/sand. stock tire size was 265/65/18 and i went up to 285/65/18 so in order to fit the slight taller and wider tires i lifted the front 2.5" and the rear 1".
next came exhaust. I wanted something that would flow better for future mods but not be too loud. turns out its quite loud but i don't regret it at all. system consist of Kooks 1 3/4" long tube headers, cat-less Y pipe, and magnaflow 3 1/2" to 4" cat back. It has a 22" muffler and 14" resonator.
Airaid intake came next along with a bed mounted tool box, on-board air compressor, aux battery with isolator, Elite brand pcv catch can with valve cover oil air separator, and a tune.
I was hauling some heavy loads and the rear was squatting too much for my liking. the following picture shows the truck with ~1,500 lbs in the bed.
I installed "helper bags" which are supplementary air springs for the rear that you only air up when you need to, to keep the truck level. here a shot of the air bags and the truck with ~2,000 lbs of rock in the bed.
About a month ago I installed some positive manifold pressure. It's a Whipple 2.9L twin screw supercharger. It has a water to air intercooler and gives me pretty good IAT's. currently its on a 4" pulley which is around 6 psi.
two week after that I installed meth injection system from alky control and a 3.75" pulley. the quality on the alky kit is amazing.
And finally. just yesterday went to a local speed shop and got a pair of AeroForce gauges. easy install all you do is plug in the harness into the OBD2 port and your good to go. gauges can show pretty much any parameter the ECU sees and can display 2 each.
File Type: jpg
Old Aug 8, 2016 | 12:49 PM
gonzo 6.2's Avatar
Good job DET,good looking truck,nice build.Do you feel like you made big gains with the Meth and pulley? And you have not done anything for extra fueling?
Old Aug 8, 2016 | 03:16 PM
Det's Avatar
Det
The ol but dyno noticed a difference. How much I don't know. No mods on the fuel system but I'm running 100% meth so that acts as extra fuel.
Old Oct 7, 2016 | 01:15 PM
Det's Avatar
Det
Got some runs in with the current setup.
race weight was around 5,750 lbs
best run was 12.41 at 110 mph
maybe next time ill get some light weight wheels and normal tires. I was running the heavy stock wheels and 80lb off road tires.
Old Oct 7, 2016 | 03:25 PM
Choda's Avatar
Awesome truck. Are you local to Roc / Buffalo?
Id be interested in seeing what it dynoed with the blower and 4" pulley compared to the meth and 3.75 pulley. what PSI is it at now?
New Era does my tuning also.
Old Oct 7, 2016 | 04:00 PM
Det's Avatar
Det
I'm on Long Island. So it's a bit of a hike.
It's running 9 psi now
Old Oct 7, 2016 | 05:44 PM
wuznme's Avatar
Mine with the 4.0 pulley is 6.5lbs, at the top end of the RPM it will slightly go over 7lbs
So I'm guessing him going down 2 pulley sizes and they say each size is 1lbs so saying he started around where I'm at 9 is about right.
I'm wanting to do the same thing with a smaller pulley and meth.
No current dyno?
I may switch gears and do the whole cam, LT4 pump, injectors etc, thing.. Still debating between that and BBK front and rear.
Old Oct 7, 2016 | 05:49 PM
Det's Avatar
Det
No dyno time yet. According to Wallace racing formula on weight and trap speed it's at 629 wheel. It's suppose to be accurate but take it for what it is.
Old Jan 10, 2018 | 07:29 AM
EarlH's Avatar
Hey, did you upgrade your driveshaft after mods?
El_Diablo
Jan 4, 2017 08:29 PM
Slammed silverado
17
Jul 30, 2016 10:22 AM
JC94Z28
Mar 21, 2016 12:56 PM
dcs191919
Feb 22, 2016 06:32 PM
John Twar
Feb 21, 2016 04:14 PM
