Holley ls valve covers on truck pcv valve
Old Feb 22, 2016 | 10:18 AM
Slammed silverado's Avatar
Default Holley ls valve covers on truck pcv valve
Just picked up some Holley ls valve covers and I saw that on my drivers side on the stock valve covers the pcv valve had a hole in it for the pcv to sit in, my new Holley valve covers just base the little tube, can I just run a in line pcv?? Here's a pick of what I'm talking about the top is the Holley valve covers and the bottom is stock
Old Feb 22, 2016 | 10:28 AM
BlackGMC's Avatar
Resident Retard
When i had those valve covers i also added a ls6 valley cover which has the pcv. I tied both valve covera together as the freah air in.
Old Feb 22, 2016 | 10:30 AM
Hmmmmm I might have to do that cause I'm not gunna run them till I put new heads and a cam in it so I'll prolly make the switch to the ls6 valley cover
Old Feb 22, 2016 | 11:43 AM
03sierraslt's Avatar
Most new trucks don't even have a pcv valve it's just a oriface. My 04 doesn't have a valve.
Old Feb 22, 2016 | 12:34 PM
BlackGMC's Avatar
Resident Retard
That is what i meant when i mentioned pcv valve.
Old Feb 23, 2016 | 08:40 PM
Did anyone add a catch can???
Old Feb 23, 2016 | 08:41 PM
im thinking about converting it to a car setup
Old Feb 28, 2016 | 12:04 PM
milesp07's Avatar
Which coil packs are you going to use? I have the same valve covers and just realized that they won't work with the truck coils.
Old Feb 29, 2016 | 08:16 AM
They won't? I have the round style
Old Feb 29, 2016 | 08:17 AM
Vortec350ss's Avatar
My truck coils bolt right to them...
